SL R230 front number plate holder
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by 18ME, Mar 25, 2013.
  1. 18ME
    18ME Senior Member
    Mar 12, 2003
    Worcestershire
    Your Mercedes:
    SL500 2003
    Just changing the plates over on the car and had an initial problem of getting the screws out of the original plates so had a little search on here regarding the rear screws being stainless and the part where they screw in being aluminium so carefully got the right size bit and managed to carefully get them out which I was very pleased and relieved that they didn't break, so rear plate now off. The front plate is a different matter, as the screws were quite rusted so normal steel I assume and one of the heads as broken off but managed to get the remaining three out without any problem but the same screws that were holding the plate on were also holding the front plate holder to the bumper. I don't want to drill the plates as I hate seeing screw holes in plates preferring to use sticky tabs to hold the plate so the question is do I use the original screws to secure the holder back on and then sticky tab the plate to the holder? If I do this method the plate will protrude a little as its going over the screws holding the plate holder. Any other methods?
  2. Mic
    Mic Senior Member
    4,156
    10
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
  3. OP
    18ME
    18ME Senior Member
    Mar 12, 2003
    Worcestershire
    Your Mercedes:
    SL500 2003
    Thanks for the quick reply. Had you just come back from a multi continent trip with all those bugs on the front?
    Did you screw the plate holder back to the bumper then stick or screw the chrome surround to the plate holder?
  4. Mic
    Mic Senior Member
    4,156
    10
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
    Ha.....I was still in France
    I do not remember exactly what I did but I suspect that I fixed the plate holder and the ''backing section'' back as one thereby avoiding the need for additional holes in the car.......I would have used new screws simply as a matter of good practise.
    Mic
  5. OP
    18ME
    18ME Senior Member
    Mar 12, 2003
    Worcestershire
    Your Mercedes:
    SL500 2003
    I think I've just worked out how they are fitted now after looking on ebay.
    There is a backing plate behind the (chrome in your case) holder that you screw to the number plate holder on the car, then the chrome part folds down and clips the number plate in place. Correct?
  6. OP
    18ME
    18ME Senior Member
    Mar 12, 2003
    Worcestershire
    Your Mercedes:
    SL500 2003
    Who are SVS?
    The chrome look good on a silver car but may look a bit too bling on a black car so may look for some plain black or carbon ones.
  7. television
    television Senior Member
    164,079
    138
    Your Mercedes:
    Some 230's have the moulded number plate holders on the front bumper like the one holding Mics plate or like mine, this is screwed to the plastic bumper and you can get the holders free from some MB dealers with the plate just clips in. Halfords do a chrome version £20
  8. Mic
    Mic Senior Member
    4,156
    10
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
    Correct
    Mic
  9. Mic
    Mic Senior Member
    4,156
    10
    Nov 12, 2009
    Oxfordshire
    Your Mercedes:
  10. drmw
    drmw Moderator
    3,492
    24
    Nov 25, 2007
    Yorkshire
    Your Mercedes:
    SL63 AMG, prior to that A-M V8 Vantage, SL55, SL500 and many more
    My Vantage had the horrible mounting plate that everyone removes. Problem is the slight curve and less than number plate height of the panel you are left with and 2 out of every 3 using double sided sticky I have seen had the plate coming away to some degree.
    There were the two holes anyway from the plinth so I drilled the plate & used a couple of chrome mirror screws with chrome domes (which I painted with lacquer - 6 months later still not a mark) - look much better than ordinary screws
  11. OP
    18ME
    18ME Senior Member
    Mar 12, 2003
    Worcestershire
    Your Mercedes:
    SL500 2003
  12. JBell
    JBell Senior Member
    5,806
    70
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    Be careful of those they are cheap plastic and can be hard to get the plate to clip in properly (my mum bought them)
    I went for these: http://www.ebay.co.uk/itm/Mercedes-...arts_Vehicles_CarParts_SM&hash=item4aa4acf0ce
    They are OEM holders and have the correct holes to mount straight on to the car, I onlt put the rear one on and drilled 2 holes in the front plate and fixed it straight to the mount on the bumper as it looks smoother.
    [​IMG]
  13. OP
    18ME
    18ME Senior Member
    Mar 12, 2003
    Worcestershire
    Your Mercedes:
    SL500 2003
    Thanks for the advise. I'll do a little research before I order any.
  14. JBell
    JBell Senior Member
    5,806
    70
    Dec 9, 2011
    Torquey
    Your Mercedes:
    No problem, from the look of your photos the front plate "mount" was held on to the bumper using the number plate screws at the top.
    The 4 bolt holes at the rear are for mounting the plate holder to, it is a 6mm close thread bolt (IIRC) so you would mount the plate holder as in my photo then the plate clips into it, I can't recommend enough the company that sells the plate surround I bought, they are, as their name implies "Awesome".
    I agree with your statement that sticky pads give a "cleaner" look but you may find as I did that the curve on the front plate means you have to screw it on.
    My front plate
    [​IMG]
  15. television
    164,079
    138
    Your Mercedes:
    My CL has a curve and I just warmed it up with the hot air gun and bent it to the shape, then it sticks on easily with the pads.
    [​IMG]
  16. kls
    kls Member
    10
    Feb 27, 2013
    essex
    Your Mercedes:
    sl
    Hi.......do you still use your nokia car phone?........if not could I buy it off you?........thanks
  17. OP
    18ME
    18ME Senior Member
    Mar 12, 2003
    Worcestershire
    Your Mercedes:
    SL500 2003
    Not sure yet whether to get the bluetooth module but if I do I'll probably keep the Nokia phone as well so that I can put it back in when I sell the car, sorry.
  18. SearchEngineGroup
    SearchEngineGroup New Registration
    Feb 5, 2015
    Your Mercedes:
    SL
    Re: television's SL Photos
    Hi Malcolm, Where can I get those number plate holders you have please? My sensors are going nuts and the number plate keeps coming off on one side... I have an R230 2010.
    Thanks - any help would be appreciated :)
  19. television
    164,079
    138
    Your Mercedes:
    Do have a word with your local dealer, they were giving the ones where the front unclips as they no longer use them free.
    I hate screws, on Ebay or from Halfords you can buy the new sticky pads, the picture of my car above has sticky pads. Where the bumper has a slight curve I heat the plate up and bend it to the contour of the bumper, this aids the sticky pads and the plate will stay in place. This weather its too cold to get a good adhesion with pads and I heat the plate up with a hairdryer/heat gun and press it firmly on.
  20. JBell
    JBell Senior Member
    5,806
    70
    Dec 9, 2011
    Torquey
    Your Mercedes:
Share This Page
