SL55 AC Compressor rattle at idle
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by candellara, Oct 13, 2018.
  1. candellara
    candellara Member
    10
    5
    Jun 26, 2006
    Bognor Regis
    Hi All,
    I've recently replaced the main idler bearing as I knew it was noisy but I think I've also a noise from the AC compressor (noticeable when the car is at idle with AC switched off)
    It's a rattle which sounds like a bearing but goes as soon as you switch the AC on. I guess this loads up the compressor which removes the rattle?
    Anyone had this issue and has anyone DIY'ed a fix?
  2. LostKiwi
    LostKiwi Senior Member
    14,507
    5,711
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    It'll be the magnetic clutch rattling. Why turn off the Aircon?
  3. John Laidlaw
    John Laidlaw Senior Member
    17,170
    4,085
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    As above, leave the aircon on normally. Are you switching it off when you drop the roof?
  4. OP
    candellara
    candellara Member
    10
    5
    Jun 26, 2006
    Bognor Regis
    Didn't really give it too much thought tbh. Just heard the rattle and then figured out it was the ac compressor. As said, probably just leave aircon on :)
Share This Page
