SLK roof retraction problem
Discussion in 'Introduce yourself' started by Laurie Aldam, Feb 13, 2018.
  1. Laurie Aldam
    Laurie Aldam New Member
    8
    Jan 30, 2018
    Your Mercedes:
    SLK 200 Kompressor
    i have a 12 year old SLK200 with a roof problem. It only goes back completly one in 10 attempts. The other 9 it all starts to work but gives up after the Windows go down and the back cover goes back. Clearly it does work but not all the time.. Any ideas of what may be the main issue ?
  2. John Laidlaw
    John Laidlaw Senior Member
    17,666
    4,319
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
  3. Craiglxviii
    Craiglxviii Senior Member
    13,350
    2,917
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Motorway Queen; W251 R320L Familybenz, S211 E320 Avg Designo Edition now sadly missed.
  4. OP
    Laurie Aldam
    8
    Jan 30, 2018
    Your Mercedes:
    SLK 200 Kompressor
    Yep. On drive ticking over
  5. mikestrivens
    mikestrivens Senior Member
    2,715
    145
    Nov 21, 2008
    Stockport
    Your Mercedes:
    I had a similar problem with my R129 a few years back, it turned out to be dry joints. A good lube put it back into working order.
  6. John Laidlaw
    17,666
    4,319
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Thanks- and assuming no convenience warnings?
  7. OP
    Laurie Aldam
    8
    Jan 30, 2018
    Your Mercedes:
    SLK 200 Kompressor
    Thanks John. I will do that when weather improves. It is hammering it down now and car back in garage
  8. OP
    Laurie Aldam
    8
    Jan 30, 2018
    Your Mercedes:
    SLK 200 Kompressor
    Sorry meant Mike
  9. OP
    Laurie Aldam
    8
    Jan 30, 2018
    Your Mercedes:
    SLK 200 Kompressor
    Correct no warning lights at all. I will try Mikes response and grease up the joints. Appreciate the reply
  10. mikestrivens
    2,715
    145
    Nov 21, 2008
    Stockport
    Your Mercedes:
    The micro switches can also be an issue, but lube is cheap so I'd do that first then look further if that doesn't solve the problem.
  11. OP
    Laurie Aldam
    8
    Jan 30, 2018
    Your Mercedes:
    SLK 200 Kompressor
    Cheers mate
Share This Page
