00slk
- Dec 1, 2012
- Location
- Cambridgeshire UK
- 2002 SL55 AMG, 2005 E320 CDi, 2014 SLK250 CDi, 2003 SLK200
- Thread Starter
- Thread starter
- #141
Ooooo good job you parked with the fronts straight or its so low you might have graunched the front wheel arch.
Hmm I thought the valves in the control blocks were metal to metal when you parked up, so it wouldnt collapse once parked ...
obviously not. :-/
Yes it was the lowest I've even seen an SL sitting. I think the valve block only lock if it sensors a problem like when the pump went on the 55, it lost quite a bit of fluid then locked the suspension in the normal position and just became super hard ride. I guess that was to reduce the suspension travel and more fluid loss?
The picture of the 500 sitting on the floor isn't there anymore I am still working on salvaging all my pictures from PB, have transferred a lot over to Flicka but still have 100's left to do. The computer that did have a lot of my pictures on went belly up just before I got around to writing a disc so kinda lost 1000's of photos including Norway and the last NZ trip That will teach me for not putting them on disc, which my eldest son was always on about for me to do. Mind you he has done disc's in the past for me but said you need to learn how to do it
