Star system
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Dean Fletcher, Sep 30, 2018.
  1. Dean Fletcher
    Dean Fletcher Senior Member
    146
    25
    Mar 24, 2018
    Your Mercedes:
    Mercedes e 250 coupe AMG 2009
    Hi all quick question can a star computer tell you what time a warning came up on the dash for instance a low coolant warning? Would it say time and date?
  2. onefortheroad
    onefortheroad Senior Member
    684
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    unsure about star, but my icarsoft tells you the date since codes were last cleared.
    Dean Fletcher likes this.
  3. LostKiwi
    LostKiwi Senior Member
    14,464
    5,685
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    No.
    alexanderfoti and Dean Fletcher like this.
  4. OP
    Dean Fletcher
    146
    25
    Mar 24, 2018
    Your Mercedes:
    Reason I'm asking is a garage has sabotaged my car. I took it in for a Mot the car was working perfectly no problems. It needed a new ball joint as the mot guy as showing me the loose wheel there was fluid ****ing out the bottom of the car I said what's that he said oh don't worry iv just topped up the screen wash it will be that I said ok. Then I went to pick it up yesterday low coolant level since driving about 5 miles the tank has gone down by a inch. The car was fine before it went in.
  5. Srdl
    Srdl Senior Member
    1,304
    491
    Oct 8, 2015
    Hampshire
    Your Mercedes:
    GLC43 AMG 2018 (X253) Premium Plus
    Since when has an MOT tester topped up screen wash?
  6. OP
    Dean Fletcher
    146
    25
    Mar 24, 2018
    Your Mercedes:
    If it was ****ing fluid how could it pass a Mot?
  7. Botus
    Botus Senior Member
    2,505
    348
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    cars go wrong at any time
    I doubt very much the MOT had anything to do with it.... they test 10 to 15 a day, the the percentage of ones they try to break must be far less than 0.1%
  8. onefortheroad
    684
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    best thing to do is find out where this fluid is coming from . has the under belly got covers on ? is it possible they hit something changing the faulty ball joint ? maybe ask for a vosa form and contest the mot test if youre unhappy. by rights they would normally fail if insufficient screen wash , they dont fill up the washer bottle.
  9. OP
    Dean Fletcher
    146
    25
    Mar 24, 2018
    Your Mercedes:
    You don't know the garage I taken it too!! Since yesterday I found out there dodgy as hell by a family friend who used to work there. I had water replaced last year he told me they told him to fit a egr valve even know it wasn't faulty to get extra cash. ******s
  10. thebiglad
    thebiglad Senior Member
    266
    134
    Aug 15, 2018
    Central France
    Your Mercedes:
    2005 CLK 270 cdi
    Before you get too close to the panic button Dean, can I just say one thing? IF the garage man topped up the coolant because he thought it needed it he might have put too much in, and then the engine has spit it out once up to temp. Mine did this when I first got it and it's not at all uncommon in other cars I've worked on.
    Just keep an eye on the level of coolant and I think you'll find it will stabilise.
    Dean Fletcher and Wighty like this.
  11. onefortheroad
    684
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    he said they topped up the screen wash not the coolant .
  12. LostKiwi
    14,464
    5,685
    Aug 25, 2006
    Your Mercedes:
    I wonder if he topped up the wrong reservoir.....
  13. L John
    L John Senior Member
    2,797
    518
    Nov 24, 2013
    Your Mercedes:
    W204 C350 Petrol Elegance
    I wonder if he just said he topped something up to explain the water.
    If it has got a leak, find out where it's from and if it looks like tool damage or normal wear.
    If it has been physically damaged it's unlikely to have been intentional.
  14. OP
    Dean Fletcher
    146
    25
    Mar 24, 2018
    Your Mercedes:
    I have had my cousin (truck mechanic) to have a look today. On the way to work it used half a tank of coolant only a 9 mile trip. Then on the way home the same again. It's ****ing out the front of the engine just in front of the fan. He says its the waterpump. So at the same garage I only had it replaced in January this year. I played holy hell and if it is the pump they will replace for free as it's still in its 12 month warranty.
    onefortheroad likes this.
  15. onefortheroad
    684
    108
    Dec 8, 2015
    uk.
    Your Mercedes:
    E
    fairly shambollock that they make a story up about filling the washer bottle, this potentially could of boiled your engine if youd gone on a longish journey .
  16. Wot1
    Wot1 Member
    14
    Oct 10, 2018
    Your Mercedes:
    2006 E320 -648
    No definately would not spit it out unless it was fill to the neck, and then how do you account for it being under filled
  17. Wot1
    Wot1 Member
    14
    Oct 10, 2018
    Your Mercedes:
    2006 E320 -648
    When it was up in the air, the thing to do would be to stick your fingers in it, the feel of glycol and screen wash are totally different including the smell of it.
Share This Page
