Peplexed..... I've owned the 2005 220 D for 8 years. Over the last year, I've had intermittent starting problems when the key would turn and be met by a small click (not a louder click normally associated with the starter solenoid). This would only occur after the car had been used for a period, stopped, and started again after a short rest (e.g. visiting a supermarket). On the 4 or 5 occasions it has happened, the problem would resolve after about an hour. The batteries have been changed and the starter motor checked. The fuse box unit (driver's side of the engine bay) has also been out and cleaned, just in case moisture was seeping in.) All ideas and advice appreciated, folks.
