Still no Goodyear Eagle F1 Assy 3’s in 275/40 ZR 19 101 Y or XL. :(
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by Submariner1, Jul 11, 2018.
  1. Submariner1
    Submariner1 Senior Member
    4,329
    569
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
    Goodyear EU told me in Oct 2016 they should be out in 3 to 6 months.
    Just rang again and they will check with Marketing and get back to me.
    Considering the marketing BS
    Steering precision and durability
    New Reinforced Construction Technology delivers a stronger lightweight contruction improving handling, cornering performance, tread wear and fuel efficiency.
    Grip for braking and handling
    The New Grip Booster compound used for the Eagle F1 Asymmetric 3, is made with adhesive resin to increase stickiness with the surface. This delivers better grip for braking and handling on wet and dry roads.
    It would Be nice to have the same type on the back. ;)
    So is 275/40/19 that unusual a size?
    All my SLs had 285s on the back
    275 x .4 = 110 mm sidewall ht.
    285 x .4 = 114 too big
    285 x .35 = 99.75 way too small
  2. AMGeed
    AMGeed Senior Member
    4,797
    1,020
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2004 W211 E55K ///AMG
    275X35X19 is the more common profile but your's must be 40 for more comfort.
    Strange to see 40 profile both front and rear on staggered rims, which is the recommended size.
    Re F1 Asymmetic 3's, OK not available in the size you want, but 2's are still available. I'd put them on if I needed rears in that size. They are still a good tyre.
  3. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    They have probably not run out of Assy 2 yet so no point in making the 3
  4. OP
    Submariner1
    4,329
    569
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
    Great minds think alike! :)
  5. OP
    Submariner1
    4,329
    569
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
    Having had 4 SL500 where the backs were all 285 on the staggerred combo.
    I was surprised too, but I always stick to the manual.
    Re my recent wheel sensor issues where 3 went bad at once, (issue now totally resolved); when I was informed the sensor values are checked against a std. and also compared to the other side of the same axle, I would be reluctant to mess with moving outside designed rolling radius parameters.
    Just in case a true, but unexpected reading started causing dash messages etc.
    At the moment they too advised on the Assy 2.
    I just thought I would check if there was about to be an imminent release of the Assy3’s .
    I would be miffed if I soent my money on Assy2’s only to find next week Assy3’s became available.
    ATM my back tyres are 3-4-4 mm and 4-4-4 mm so being a nasty budget Accellera (OKish in the dry .... well easy to make squeal unintentionally, but scary in the wet ergo turn a corner and push it, and you can induce the rear to glide out frightfully easily.)
    So if the Assy3 are not coming out in the next month, Assy2 will be the ine I go for.
    AMGeed likes this.
  6. vtaylor78
    vtaylor78 Senior Member
    747
    97
    Jan 5, 2012
    Northamptonshire.
    Your Mercedes:
    E350 CDI Coupe W207 2010
    What’s the difference between 2 & 3’s ?
    Anybody know.
    I’m quite happy with my 2’s.
  7. OP
    Submariner1
    4,329
    569
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
    Apparently an improved compound claimed to improve braking and road holding especially in the wet.
    A few German tyre appraisal sites claimed its a big difference ...
    Is it really ? Who knows?
    But they did get better scoring on 3 sites.
    Personally I just like having the same tread pattern and compound all round.
    More out reassurance, as I am not qualified to appraise any differences.
    I just assume all wheels will react the same way to a given road surface/condition.
    vtaylor78 likes this.
  8. OP
    Submariner1
    4,329
    569
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
    Goodyear got back to me.
    None in this size until 2020!
    Guess its either :-
    1. No new cars have this size tyres, so not worth making them.
    2. Little demand for this size, and they have loads on Assy 2 compound, so its not retooling for a tyre in little demand.
    3. They have massive stocks of Assy 2 in this size unsold. But are they really planning on selling 2 year old tyres?
    Anyway not brilliant news.
    So Assy 2 it has to be. :(
    I guess they will be as good as anything else available in the £160 price bracket ?
  9. flowrider99
    flowrider99 Senior Member
    2,168
    516
    Jul 21, 2014
    Your Mercedes:
    SL500 (R230) / Audi S5
    Plenty of online discount retailers will sell 2 year old tyres , Tyreleader being one. Most people wont notice the age of the tyre they bought.
  10. Craiglxviii
    Craiglxviii Senior Member
    13,190
    2,810
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    W215 CL500 Garage Queen; W211 E320 Avantgarde Estate Designo Edition
    Submariner1 likes this.
  11. OP
    Submariner1
    4,329
    569
    Sep 3, 2016
    Windsor Berkshire
    Your Mercedes:
    CL500 2009 5.5
  12. AMGeed
    4,797
    1,020
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
  13. Craiglxviii
    13,190
    2,810
    Sep 6, 2015
    Cambs UK
    Your Mercedes:
    Those are the 19”.
    Buy from Camskill and get your fitter to fit them. That’s what I’ve done, @ £15 per corner.
  14. JBell
    JBell Senior Member
    9,156
    1,583
    Dec 9, 2011
    Torquey
    Your Mercedes:
    They will sell them, they will be fine to use as they store them properly.
    If you think that is bad Continental in MO spec is the SC2, bearing in mind we are on the SC6 that is a VERY out of date tyre!!!!
    The only other tyre I would look at is this:
    https://www.camskill.co.uk/m55b0s16...Eff_:_E_Wet_Grip:_A_NoiseClass:_1_Noise:_67dB
Share This Page
