EmilysDad
Very interesting read chaps.
My R class and
Ah! I'm not alone in driving one
My R class and
He’s the chosen one!!Ah! I'm not alone in driving one
My R class and C class do not have this feature.
The company golf has covered 275K in 5 years without any issues, I wonder how much of thisnisndown to the fact that even in any type of traffic the first thing I do is switch stop/start off.
I'm not that's right as when the engine is producing power and torque it gets passed through all the moving parts attached to the crankshaft. Although there may be a jerk at start up its from a low torgue starter not the engine at working power. I understand what you mean but unsure if its correct.difficult to prove but i am convinced it makes a big difference, i believe there is a fair amount of load on the cam chain system at start up and a negligable amount once running. and i certain yr starter wont like it much either .long topic , seems majority view, its a waste of time. just another headache on the way, thinks, if i want it off i can manage to off the key myself.
the load to get a cam moving is massive - (without using tools or levers...) if I put a 4 pot 2 valve OHC cylinder head in front of you, with the std cam drive wheel in place, no matter how hard you try its highly unlikely you will be able to turn the cam even 1/4 of a revolution
once its running a 1000revs an average mum could maintain the load required to keep it turning without trying....
Compression forces don't go through a chain, turning the camshaft from stationary does.How did we used to manage to start cars in the olden days with a starting handle when your battery failed, with say 50lbft of torque. It may be easier when its built up momentum but does starting torgue equal running torque or average running torgue.
I would expect the biggest forve to overcome in starting is the compression not turning the cam shaft anyway. But I am no expert just speculating.
The higher the rpm the less force on the chain. Two reasons for this. The force is only on the tension side of the chain and the higher the rpm the less time any given link is under stress before having stress removed (hence less lubricant forced out between the links) and secondly the camshaft and cam sprockets have momentum thus take away the peaks of load making the peak stresses lower.
In terms of overcall effort at start up the valve train probably accounts for 20-30% of the total effort of turning the engine over (compression and piston to bore friction accounts for the rest).
The point is that starting from rest is the highest load on the chain so stop start will aggravate any weakness in the valve train and specifically the timing chain, especially given there is no oil pressure at this time either so minimal lubrication.
Thanks for your explanation and I understand the point but i'm still not convinced but will give it some thought.
There also seem to be other engines with cam issues discussed here that don't have stop start, particularly the 1.8 petrols of a certain era.
Think of riding a bike it feels hard when you set off but going up an incline etc and there is just as much or more stress on the chain. A different type and function of chain of course.
I'd say that double row chains are more reliable and trouble free in any case, regardless of stop/start or make of engine they are fitted in.I think its a combination of both introduction of single row timing chains, and stop start systems at the same time.
I would bet money that double row chains with stop start systems have fewer issues.
