SteveJ69
My R230 Sl55 (2003) has been parked under a cover since Nov, with little use appart from short runs to keep things moving.
Last month I noticed it wouldn’t unlock, but would start, but with the usual electric consumers offline message. Anyway removed the battery, gave it a full charge, re-fitted and all good.
There has always been a little damp in the boot but I’ve removed everything and dried it. Also had a full valet ready to sell.
Anyway yesterday I decided to take the sl on a 100 mike journey to my girlfriends. All well and didn’t miss a Beat on the journey. Parked the car on her driveway over night. Returned to it this morning started it no problem. This evening the car will lock and unlock but will not start.
Warning on the dash says ESP defective (which I had previously when the supply batter was low), but it doesn’t even attempt to crank. The other thing is the radiator fan starts running at full speed. Fuel indicates and water doesn’t (engine is cold) and the red water temp warning is on (never noticed if this is normal on startup).
Tried a jump start with leads on starter battery, no dice. I’m not convinced it’s battery as all werwell charged and she started without issue today.
The car is also definately In park and I hve also cycled the transmission lever.
Any thoughts? I can RAC it home but would be good not to have to.
Cheers
Cheers
