Strange boing Noise when cornering or uneven ground
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by Brian23, Oct 12, 2018.
  1. Brian23
    Brian23 Senior Member
    1,186
    13
    Jan 11, 2008
    Your Mercedes:
    EClass
    Hi I was driving my wife's 1999 230 SLK the other day and when you corner or go over uneven ground, there is a boing noise from behind could be in the boot/boot lid or outside. I've looked in the boot and at the rear springs, but nothing obvious. Any Ideas?
  2. LostKiwi
    LostKiwi Senior Member
    14,464
    5,685
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    Nothing rolling around in the boot or under the boot floor?
    No broken springs (can be hard to see as they usually break on the bottom coil)?
  3. OP
    Brian23
    1,186
    13
    Jan 11, 2008
    Your Mercedes:
    EClass
    No nothing in the boot anywhere and MoT today, so spring check. It has actually been doing this for a couple of years and been through a couple of MoT's. I only try and find it when I drive it. It is as if a tension bar, as in the old style boot lids is moving, but, non on this car. It is not like a clunk. It's a slightly prolonged sound.
  4. antijam
    antijam Senior Member
    1,594
    27
    Jul 20, 2008
    Gloucestershire
    Your Mercedes:
    2003 SLK320
    Sounds very like a broken rear spring. As LostKiwi points out, they can be very difficult to see since the failure is almost always the bottom coil which, after a few years, ends up sitting in a poultice of salty mud and corrosion inevitably takes its toll.
  5. OP
    Brian23
    1,186
    13
    Jan 11, 2008
    Your Mercedes:
    EClass
    Just this morning passed it's MoT and I cannot see anything wrong with the springs either when it is jacked up.
    19 Years old and only failed last year due to the headlights needing to be polished.
    Wighty likes this.
  6. M80
    M80 Senior Member
    3,121
    427
    Jan 21, 2006
    Derbyshire
    Your Mercedes:
    Viano 3.0 ExLWB (09)
    I'm not familiar with your mo mo but had similar with Larisa'a Jeep,
    turned out to be the rear A fame centre bush. Difficult to access and above other parts it was diifcult to diagnose.
  7. OP
    Brian23
    1,186
    13
    Jan 11, 2008
    Your Mercedes:
    EClass
    thank you
  8. antijam
    1,594
    27
    Jul 20, 2008
    Gloucestershire
    Your Mercedes:
    2003 SLK320
    This is where my SLK spring failed, and I couldn't see the fracture until it was removed. My car too had passed an MoT with the 'boing' present - but obviously not audible during the test.
  9. Blobcat
    Blobcat Moderator
    9,417
    629
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    My smart passed it's MOT also with both front springs broken - Drivers side (pic below) at the bottom and passenger side at the top. Not visible only a clicking when turning.
  10. OP
    Brian23
    1,186
    13
    Jan 11, 2008
    Your Mercedes:
    EClass
    I'll take another look tomorrow.
  11. Uncle Benz
    Uncle Benz Senior Member
    2,230
    333
    Mar 31, 2006
    West Sussex
    Your Mercedes:
    Mainly Mercedes
    If you look at the wishbone where the spring sits down into the recess you can sometimes see a rusty or shiny mark where the spring has been rubbing on the wishbone. A break at the lower end, or sometimes just excessive rusting of the lower part of the spring means it won't sit central in the wishbone hole, and boings on the side of the wishbone hole when the suspension goes up and down.
    Blobcat likes this.
  12. OP
    Brian23
    1,186
    13
    Jan 11, 2008
    Your Mercedes:
    EClass
    Thank you I will take a look.
  13. Yugguy
    Yugguy Senior Member
    2,086
    434
    Mar 4, 2016
    Rugby, UK
    Your Mercedes:
    C220CDI W204 Elegance Comand
    Zebedee is hiding in your wheel arch.
  14. OP
    Brian23
    1,186
    13
    Jan 11, 2008
    Your Mercedes:
    EClass
  15. John Laidlaw
    John Laidlaw Senior Member
    17,140
    4,077
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    Ah the old ‘dot’ eh? :cool:
Share This Page
