STromberg 175CDT Carb
Status
Not open for further replies.
Barnie
Scottish Borders
Can any one tell me where I can lay my hands on a instruction manual for this particular make & model of Carb?? .
The basic principle of the carb is quite simple, however its the bolt on electrics that are giving me some problems. Do "Stromberg " have a Web site?.
"Stomberg 175CDT SIDE DROUGHT"
(Edited by Barnie at 11:34 pm on Sep. 6, 2002)
sunil sood
presumably,this carb you mention is fitted on the earlyW123 series mercs.
there is good coverage of this carb in the following manual;;
MERCEDES W123-1976-1986 OWNERS WORKSHOP MANUAL-PUBLISHED BY TECHNIBOOKS
JANUS PUBLISHING.
CHECK THE website chaters.co.uk=do a power search-once on the search page, enter the following number in the ISBN section of the search 0-620-16443-3-the book is available at £19.95-the info you need is in chapter 6-the fuel system-hope this helps.
B
Barnie
Scottish Borders
Thanks "sunil" for your info , I checked out the site as per your advice ,however my car is a 1988 -124-200 & the carb is of Pierburg manufacture "embossed on casing" but is also stamped 175CDT & is identical in principle & design to the Stromberg 175CDT .confused? I am!
I located the book on the Chaters site but was unable to find a way of checking the CONTENTS eg( the fuel system) to see if similar to mine.
Regards,    Barnie
sunil sood
your local library may have copies of car manuals-mine certainly has.
you could try there.
sunil sood
you could also pop into your local halfords store-they may have a copy of haynes manual which covers the 124 series merc.
B
Barnie
Scottish Borders
Thanks "sunhil" I appreciate all your replies & help I shall follow them thru & let you know if I come up trumps
Regards Barnie
ps Does your car realy have 8ltrs under the bonnet ??
sunil sood
barnie,
if i had 8 litres under the bonnet-the car would be taking off!
it is a 1.8 litre-190e
B
Barnie
Scottish Borders
S. Silly me I'LL have to get my glasses changed, mind you I have seen some some fantastic conversions in my time the most memerable being a 4ltr Jag engine fitted very snugly into a Ford Prefect. Some Mothers do av em.
regards Barnie
Status
