Swap of Comand NTG3 Panasonic (Japan) to Europe NTG3 (Becker)
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Frode Storkaas, Feb 6, 2018.
  1. Frode Storkaas
    Frode Storkaas New Member
    Feb 6, 2018
    Your Mercedes:
    W221 S65 AMG 2006 + W210 E55 T AMG + W169 A180 CDI
    I own a W221 2006 that was imported from Japan. The navi does not except to dowload Europe map DVD, the watch is not possible to set correctly, the FM scale stops at 90 Mhz.
    There are no Connections in the glovebox, and the Bluetooth Works only for the phone. (Iphone, no music)
    Is it possible to buy a Europe Map that can be installed With the JP NTG3 ?
    If not, is it a plug and play job, to replace the JP comand With a European Becker NTG3 comand ? (Connections the same).
    If replaced With the Europe Version, is it possible to add DAB+ in some way ?
  2. Botus
    Botus Senior Member
    1,783
    100
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    DAB is a separate module in the boot.... you can fit the facelift module ..... you need to have updated firmware to birdseye (3d maps mod).... which I expect will only go on the European unit.
    DAB about 100 quid, plus a loom and some fun talking the seats out (or try and aftermarket bodge)
    the NTG 3 units are still pricey secondhand, you could try and get an NTG 3.5 package with the later better screen and the 3.5 head unit but your talking about 800 to 1K... and u still need the module in the boot for the DAB
  3. Alfie
    Alfie Forum Supporter Authorised Forum Supporter
    2,276
    66
    May 12, 2005
    Surrey
    Your Mercedes:
    You can swap the units but its not just plug and play. You will need coding and once it is all in then yes you can add DAB (in2digi)
  4. JBell
    JBell Senior Member
    7,534
    735
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    Stick a decent Pioneer / Kenwood / Alpine unit in it, better functionality and much more modern
  5. OP
    Frode Storkaas
    Feb 6, 2018
    Your Mercedes:
    If changed to another Component, The navi, phone, display and other details that are using the Comand to function would not be functioning.
  6. OP
    Frode Storkaas
    Feb 6, 2018
    Your Mercedes:
    I have bought an European comand NTG3, and will change the unit. However, the wiring of the Japanese cars are a bit different than the Europe Version. Are there anybody at this forum that has the wiring diagrams for these cars ?
  7. Alfie
    2,276
    66
    May 12, 2005
    Surrey
    Your Mercedes:
    The wiring diagrams are Mercedes copyright.
  8. LostKiwi
    LostKiwi Senior Member
    9,479
    2,690
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500, 04 Smart Roadster Coupe
  9. OP
    Frode Storkaas
    Feb 6, 2018
    Your Mercedes:
    The wiring diagram for the European unit was sent by e.mail to me from Mercedes rep. Anybody out there that has the Japanese Comand NTG3 info ?
  10. Alfie
    2,276
    66
    May 12, 2005
    Surrey
    Your Mercedes:
    Well he shouldnt have!
    Good luck finding the Japanese version. Ive got all the Mercedes wiring diagrams for ECE and USA as part of WIS. Ive never seen the Japanese ones in there which fits in with the fact that we cannot lookup Japanese VIN numbers in EPC either.
Share This Page
