monkeh
- Jul 17, 2017
- 2007/8 Chrysler, 300c, OM642 lump
I notice another member on here is having similar issues to me,
I recently overhauled the sooty mucky mess on my 300c's inlet manifold. Swirl flaps were sooted up with some of the manifold blocked with a 15mm sooty hole breathing into one of the cylinders. God knows how it ran tidy.
So... 12 cans of carb cleaner and a hot degreasing bath for the inlet manifolds later, Its all buttoned up back together with the EGR blanked off pending removal by remap guy. Swirl flaps jammed open (bar one, I broke the linkage) and resistor fitted. Ran lovely for a few weeks until I accelerate... 60mph, Brick wall, Turbo stops, Deep drone and no boost. Ignition off and back on, Itll run great. 0-60-80, whatever, It runs perfect AFTER ignition off.
My conclusion is maybe I botched up jamming the swirl flaps open. I have a friend who has exactly the same issue, who has confirmed that he has had a botched job on his swirl flaps...
Now, My question... Physical removal of these flaps are in the line, With 3 of us lining up to rip these ****** things out. Has anyone removed these from the OM642 engine with any adverse affects on drivability and fault codes?
I know what they do, with side effects of smoke low end acceleration, But with the 3 of us running remapped cars, it wont be an issue.
Thanks all...
Thanks all...
