gramey
- Jul 23, 2016
- Location
- Ipswich, Suffolk
- Currently none
The soft close on my boot worked when I bought my car back in March but when I had issues with the consumer battery it went down and I didn't bother to do anything about it as the problems at that time were ongoing.
The battery issue was sorted out long ago but I just got used to giving a sharp push on the boot, which I rarely use anyway, to close it fully.
So today I thought I'd disconnect the battery and see if it would reset it, which it appeared to do, it worked fine for the three times I tried it. I needed to pop put out this afternoon, and popped something in the boot which again closed as it should. I then got in and put the roof down, when I got to my destination, roof still down, I went to the boot but this time when I closed it the soft close didn't work.
I always thought the soft close not working occurred as a result of the battery voltage dropping but does anyone know if there is a reason opening the roof may cause it not to work. It obviously still wants to work because if I disconnect the battery with the roof up it resets and works until I put the roof down?
I've read about the locking mechanism cracking and not holding pressure, could it be this and the roof operation is a red herring?
