Trueblue1872
- Feb 2, 2018
- Location
- Scotland, United Kingdom
- W203/2004/1.8 Kompressor
Trueblue1872Senior Member
Hi there guys I hope your all well......I was hoping I could ask u a quick question. I'm not sure if you remember but I had an oil leak and had to change out my Cam Magnets. Well that has since been done and after doing so the car was running well with no problems and the gear shifting also seemed to improve. after driving for around 50 plus miles earlier today I had a check engine light and the other ones for the system too rich and lean where still there but a new one had appeared it was
P0020 A Camshaft actuator circuit/open bank 2
do you know what this is and how it can be fixed. I also noted knew symptoms of rough idling as well which is just started since seeing this fault code. I hope you can help
many thanks
