Arudge
- Jun 14, 2016
- Location
- Cradley Heath
- CLK200 2000 Kompressor
This is a bearing track that has Broken up and is the sort of damage I'd expect to see in the OP case.
Why? Bad material, bad heat treatment (too hard) or bearing too tight and the subsequent heat generated will destroy the surface.
If you look closely at the image you may notice vertical lines, this is possible heat bloom on this roller bearing, suggesting it's been over tightened leading to complete failure.
I'm sorry but MB do not use super high quality bearings, you'll find exactly the same sort in a washing machine!
