Hello everyone,
I have some errors on my car, one is with the right turbo(mechanical works well but electrical parts does not move the valve) and the EGR valves works well(both) but the electrical parts does not move the mechanical valve. At the turbo I have open the electrical box and seems to look fine(no oxide, no burned parts and the motor works). The engine does not run more than 3500rpm in P and when I drive it on the roads, in every gear does not run more than 1800-2000rpm, even when I push the pedal to the top(kick down). If I push up to kick down and I keep it there for some seconds, the EPC light appears. Does anyone can help me? One mechanic said to me it is the problem with the vacuum system.
Many thanks in advance,
CristiRO
CristiRO
