EdGasket
I discovered the inner edges of both front tyres very rounded and bald while the centre of the tyre still has around 5mm tread on it. I swapped fronts to back and also toe'd the steering in a little (half a turn on each side) to see if that would help. Now these tyres are also becoming rounded on the inner edges. Is this a symptom of the Esprit's lowered suspension?
Looking at the car with the steering in the straight-ahead position it looks to me as though the wheels/tyres are splayed out at the bottom so that the wheels appear to lean out at the bottom and in at the top; with most car weight on the inner tyre edge. Am I imagining this or can the suspension sag on an 18 yr old car with 157K miles? The lower balljoints have been replaced recently and no mention of anything else in the MoT. Wheel bearings have also been adjusted. Are the springs worn out or is there anything else I can do to correct the tyre wear?
