M80
- Jan 21, 2006
- Location
- Derbyshire
- 2014 639 Viano- 651, 5sp Auto. 2009 S211- 646, 5sp Auto.
In preparation I think it’s worth dropping the belly pans. The 1st time you drop a bolt or socket the pans have to be dropped anyway, this way now you just pull out the belly pan to recover the dropsy. Then put the belly pan back to catch the next.
When feasible I prefer to remove the item and screw bolts back where they came from to reduce the confusion of “where’s this one from”.
Setting up with torches, grab claw, extendable magnetic led and masking tape were very useful.
A roll of ‘heavy duty’ kitchen type roll from the £ shop worked a treat, as did a few pairs of the blue nitrile gloves.
To clean I spray white spirit onto the towel and wipe.
_______________________________________
The fault was the car going into limp home mode.
Various fault codes were present but many due to the under bonnet fuse number 54 (15 amp) having been blown by the inlet port shut off motor.
A known problem is the air intake duct is sealed to the turbo Intake spigot by a rubber seal. This seal allows oil to pass that finds it’s way onto the shut off motor below, causing it’s eventual failure.
_________________________________________
Remove engine cover.
Remove heat shield above turbo,
3 bolts, image (b).
Remove o/s heat shield support bracket (engine hoist point),
2 bolts
Remove air filter retaining bolts,
2x2, 4 bolts in all.
Loosen jubilee’s on air filter to air intake duct, ease air filters sideways away from engine,
2 jubilee’s.
Unplug 2 MAF’s at air intake duct,
image (a).
Remove PCV inline heater from air intake duct and unplug, this will need to be moved away from the work area,
image (a).
If you wish to replace the rubber seal consider that this is supplied c/w a heater, £22 +vat.
Mine was passing oil and was an unreliable seal into the duct.
A new one will be more difficult to push into the duct on re-assembly.
At air duct to turbo spigot loosen the jubilee, and ease air duct backward and off,
image (b)
We are now up to the 3rd revision in design of the air duct (approx £250 +vat). The new style rubber seal between air duct and turbo intake spigot, ‘the cause of the issue’ is now shorter but also fatter. On re-assembly pushing the seal onto the spigot is very difficult, maybe the later design makes for this to be easier ? Don’t loosen the jubilee to much at re-assembly as it offers support to the plastic surround and can prevent it splitting.
I ran a bead of silicon sealant around the inside of the air duct where the seal sits, looking at the old seal there was a gap between the seal and the turbo intake spigot (see image (o)). This would allow the oil to pool and eventually run, I hope to prevent any repeat of this.
image (n) & image (o).
3 bolts, image (b).
2 bolts
2 jubilee’s.
image (a).
image (a).
image (b)
