VIN decoder?
gianton
Thessaloniki, Greece
S204 C250 CDI 4Matic Avantgarde - 2013
well due to creaky knees the cls had to go found it low to get in plus the wife has broke her hip so have got a e320 estate
could i have a data card please vin no wdb2112222b440795
Datacard attached.
  • wdb2112222b440795.pdf
brzozowa128
w126 82
Hiya, After months of looking I got myself a rather beautiful w126 1986 VIN WBD1260242A230061. Can someone please generate a data sheet so I can see what exactly is has, in additon to its charm :)? Cheers!
John Laidlaw
Wirral
Land Rover Discovery 4
Double check the Vin number please, that one is not generating any data
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
See highlighted below
QUOTE="brzozowa128, post: 1543229, member: 85003"]Hiya, After months of looking I got myself a rather beautiful w126 1986 VIN WBD1260242A230061. Can someone please generate a data sheet so I can see what exactly is has, in additon to its charm :)? Cheers![/QUOTE]
I guess you meant WDB126...
Datacard
Identification number: WDB1260242A230061 9
Chassis
Sales designation: 300 SE
Order number: 0 6 537 01095
Paint code 1: 473 ENGINE W/LOW COMPRESSION RATIO, WITH CATALYST
Equipment: 074 No code designation available
Engine no.: 103981 22 009099
Transmission: 722319 02 753744
SA code
074A No code designation available
251 RADIO MB - EXQUISIT - USA
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
412 _______ - 19951002 - ELECTRIC SLIDING ROOF
412 _______ - 19980716 - ELECTRIC SLIDING ROOF WITH TILTING DEVICE
420 AUTOMATIC TRANSMISSION 4-GEAR
470 _______ - 19780601 - ANTI-LOCK BRAKING SYSTEM (ABS)
470 _______ - 19700401 - FAN CLUTCH
470 _______ - 19661201 - SPECIAL EXPORT VERSION 3
481 UNDERSHIELDS
507 No code designation available
531 AUTOMATIC ANTENNA
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
570 FOLDING ARMREST, FRONT
584 ELECTRIC WINDOW LIFTER, 4-WAY, V 124, 6-WAY
592 ALL-ROUND WD-GREEN GLASS,HEATED REAR WINDOW-VSG
615 No code designation available
Copyright Daimler AG , 23/07/17 19:35 , EPC 2.5.1.0 DW 04/2017 , User: admin Page: 2
640 15-HOLE LIGHT ALLOY RIMS
731 WOOD TRIM BURRED WALNUT ROOT
SA numbers
Group 15
15 12418/13
Group 22
22 10919/50
Group 24
24 10919/50
Group 33
33 11171/07
Group 40
40 10858/61
Group 42
42 11173/03
Group 46
46 11347/01 46 11347/21
Group 49
49 11249/11
Group 52
52 11115/03
Group 54
54 10842/36 54 11173/03 54 11174/09 54 11184/82 54 11217/02
54 11281/13 54 11283/12 54 11286/03 54 11289/04 54 11318/61
Group 58
58 10917/06
Group 60
60 56044/10
Group 62
62 56044/10
Group 67
67 56322/05
Group 68
68 56463/01 68 56468/01 68 56468/24
Group 69
69 56155/28
Group 72
72 56080/34 72 56322/05 72 56372/01 72 56383/01 72 56399/05
72 56463/01
Group 73
73 56322/05 73 56383/01 73 56399/05 73 56463/01
Group 78
78 56414/08 78 56499/06
Group 80
80 55894/13 80 56040/13
Group 81
81 56075/06 81 56080/34 81 56463/01
Group 82
82 56040/13 82 56075/06 82 56080/34 82 56155/28 82 56372/01
82 56383/01 82 56424/01 82 56424/03 82 56424/04 82 56424/05
82 56424/09 82 56424/17 82 56425/07
Group 83
83 56128/08
Group 97
97 56338/01
Other
Lamps: BOSCH
Wipers: 000000
brzozowa128
w126 82
Apologies for a typo, the one you gave is correct! I am way too excited! Where to find further specs?
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
To the Vin Decoder guru's, is it possible to get details from the vin of a non MB car? If so can I pm a vin number to a guru to then pm me the details back please?
John Laidlaw
Wirral
Not sure TBH, ping me the VIN and I'll try
bob 6600
Nope. The online sites use EPC as their base so using Mercedes' database.
If it's a VAG you can usually get the PR codes and decode them
Mallo
Newcastle
'11 W221 S500
Hi there, I've just traded my 05 CLS55 for an S320 CDI W221 (work means I need a diesel as am doing more miles) vin :
WDD2210222A219431
If someone would be very kind and look it up I would be most grateful, thank you.
Simon
AMGeed
Poole, Dorset
S204 C180K
WDD2210222A219431
Simon
Here you are Simon.
Parameter Value
Ident. number (FIN) WDD2210222A219431
VIN WDD2210222A219431
Baumuster 221022
Sales name S 320 CDI
Order number 0 8 537 05443 (Destination: Great Britain)
Delivery date 03 03 2008
PAINT1 775U BRIGHT SILVER METALLIC CLEAR COAT PAINT
Interior color 201A LEATHER - BLACK/ANTHRACITE
Engine 642930 40 646067
Gearbox 722902 01 700057
General data for model code 221022
221022 S-class W221
642.930
722.902
SA codes
Parameter Value
200A LEATHER
205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH
220 PARKTRONIC SYSTEM (PTS)
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
250B MOBILO LIFE/EUROPE SERVICE PACKAGE
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
283B AIRBAGLABLE - ENGLISH
289 LEATHER STEERING WHEEL WITH TRIM INSERT
383B BATTERY LABEL - ENGLISH
386 UNIVERSAL TELEPHONY PACKAGE
427 AUTOMATIC TRANSMISSION 7-SPEED
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
474 DIESEL PARTICULATE FILTER
477 TIRE PRESSURE LOSS WARNER
527 COMAND DVD APS WITH NAVIGATION
537L GREAT BRITAIN AND NORTHERN IRELAND
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
581 AUTOMATIC CLIMATE CONTROL
5XXL EUROPE
600 HEADLAMPS - CLEANING EQUIPMENT
616 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT LEFT-DRIVE
619 CORNERING ILLUMINATION
666 PRODUCT PROT.F.TRANSPORT VEH. W/O TIE-DOWN HOOKS
690 EMERGENCY SPARE TIRE (MINI SPARE)
731 TRIM PIECES - WOOD BURRED WALNUT VENEER
808 AEJ 07/1
808 *1 221____ 20030729 AEJ 07/1
808 *2 642.9__ 20051220 AEJ 07/1
808 *3 722.9__ 20050822 YOM 17/1
814 DVD CHANGER
817 SIREN BRACKET FOR INCREASED THEFT PROTECTION
875 HEATED SCREEN WASH SYSTEM
882 INTERIOR SAFEGUARD
885 HIGHTEN THEFT PROTECTION
910 DYNAMO WITH HIGHER CAPACITY (FFO)
983 COC PAPER EURO 4 TECHNOLOGY W/O REG. CERT. PART II
989 IDENTIFICATION LABEL UNDER WINDSHIELD
A21 SHIFT BY WIRE
A22 NEW CONVERTER GENERATION
A24 JOINT FLANGE, 4-ARM 120
A38 M - VALVE BODY ASSEMBLY WITH VGS 2
A44 SOFTWARE 3
A49 CONVERTER WITH 3 FRICTION DISKS
F221 SERIES 221
FW LIMOUSINE
G902 TRANSMISSION CODE VERSION 02
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
K10 SOFTWARE CONTROL FOR STATIC CURVE ILLUMINATION
K11 ADAPTIVE STOP LIGHT FLASHING
K13 CONTROL CODE FOR SERVICE INTERVAL 25000 KM
M30 DISPLACEMENT 3.0 LITER
M642 V6 DIESEL ENGINE OM642
NB0 NEW VEHICLE DOCUMENTS: DAIMLER AG
Q50 GV - PERFORATION VA-BREMSSCHEIBEN
R RIGHT-HAND STEERING
R01 SUMMER TIRES
R31 18" LIGHT ALLOY WHEEL 5-SPOKE DESIGN ALL-ROUND
U18 AUTOMATIC CHILD SEAT RECOGNITATION (AKSE)
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
V24 SPEED- + LOADINDEX 99Y
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
Mallo
Newcastle
'11 W221 S500
B
Here you are Simon.
Parameter Value
Baumuster 221022
221022 S-class W221
642.930
722.902
SA codes
Parameter Value
200A LEATHER
5XXL EUROPE
808 AEJ 07/1
814 DVD CHANGER
A21 SHIFT BY WIRE
A44 SOFTWARE 3
F221 SERIES 221
FW LIMOUSINE
HA REAR AXLE
R01 SUMMER TIRES
brilliant! Thanks!
ANSPR7
CHORLEY
C 220 d Estate / S205 / 2017
Just been notified of the details of my new company car and keen to better understand the spec details. Grateful if someone can assist with a decode of the following VIN:
WDD2052042F613946
Many thanks in advance.
gianton
WDD2052042F613946
Smth's wrong with your VIN.
