Stretford mongrel
Registered
- Jan 17, 2018
- 220CE W124 1993
New battery and alternator charging out at 14V so these should not be an issue. Turn on ignition dash lights up, seatbelt extenders operate etc. Turn to start and no turn over. Can hear fuel pump but no turnover not even a starter motor click. From cold it starts no issue. Drive half a mile. Turn off then nothing. I have found if turn key and hold at start for few seconds 4 or 5 it then will turn over. But the usual start of just turn the key to start and it turns over doesn't seem to kick in but if it is held it does turn over although sometime slower than usual. Any ideas on what to check especially at the time it won't start. Garage gets it and it is working so can seem to find fault. Could it simply be ignition switch (100,000 miles) starter solenoid, bad earths? Thanks for any help.
