W124 Coupe Buyers Guide
jaymanek
Nuneaton, UK
www.mercland.com
Hi All,
Over the years I have written some buyers guides for the popular magazines. I thought they may help here.
I hope these is no issue with that.
If there is anything wrong, please dont hesitate to correct me. The final printed versions were heavily scaled down by the magazines. These are my raw words and my opinions based on my experience only.
Engine
All of the W124 coupes are fuel injected. All engines are thoroughly reliable. With age, some will exhibit some age related issues requiring maintenance.
Across all of the range, it is important to look for oil leaks, good oil pressure and a generally smooth running engine.
Maintenance is the key to long term sound running.
The cooling system is an important area to check across all engines. In all UK weathers, the temperature should not climb above 90 degrees at standstill and should sit around 85 when cruising. Any overheating could indicate a worn water pump, a failing viscous fan, a blocked radiator or issues with the electrical side of the system.
A poor cooling system will quickly lead to head gasket failure.
All engines use a variant of the Bosch KE Jetronic fuel system. A very reliable system, however with age, the electronic components such as fuel relays, OVP relays or idle valves can have even the most knowledgeable mechanic scratching his head. Diagnosis on these older cars is not like modern cars. Each component has to be tested in a logical but often laborious manner.
However, in most cases, issues are usually down to dry solder joints or poor wiring.
The fuel injection and ignition system itself is extremely durable.
M102 Engine
The 230CE M102 engine uses a duplex chain drive which does not usually exhibit any wear until it reaches very high mileages.
Some common issues are split breather hoses causing a poor idle. A stuck idle valve will have the same effect.
Head gaskets can require replacement with age which is around a £800 job if required.
If the engine sounds tappy at idle, the hydraulic lifters may need attention.
M103/M104 Engine
The M103 & M104 engine uses a duplex chain drive which does not usually exhibit any wear until it reaches very high mileages.
Wiring Looms to be inspected, these are of the era when wiring looms were biodegradeable and may need replacement if they have degraded. Cost anything between 700-1500 incl labour.
Poor wiring looms not attended to will lead to failure of the ignition control unit.
Condition of the wiring loom is easy to spot, just look at the connectors and gently pull back any outer cover. Any cracked or bare wires is a bad sign.
There are some companies offering refurbished or aftermarket looms which can save a lot on the cost.
Head gasket is a common problem on these m104 engines. Check for leaks, especially at back of engine. Cost to replace around £1500 if not other damage.
All of the M104 engined cars (300-24, & 320) can require water pumps at this age, using genuine parts this is around a £600 job.
Also if vehicle runs hotter than normal, the viscous fan may need replacement.
The M103 6 Cylinder engine has a common issue with its distributor cap letting in moisture. If the car starts fine but then starts to splutter as it gets warm, this is the issue. Solved by a new distributor cap, seal and rotor arm. It is imperative to change these items regularly with this engine.
Most models have an engine oil cooler located on the front left side of the car, inside the front bumper. These can corrode and leak oil. This job often requires both the radiator and pipes to be replaced. The job can be tricky and with garage labour will cost up to £750 or so.
Exhaust
The exhaust system is well made across the range and have been proven to last 15-20 years.
At this age the system should be inspected for leaks. Parts are still available from Mercedes but not all parts are affordable.
Many owners choose to replace exhaust systems with custom made stainless steel items, which usually come with a lifetime guarantee and are cheaper than buying a genuine system.
Transmission
The transmissions on the W124 series are very strong and well proven.
The 5 speed automatic transmission is known to have issues with the electronic 5th gear solenoid, therefore it is important to check that all gears are engaging. Remember the vehicle will set off in second gear from stand still. However, the five speed is the preferred choice of long distance drivers for both comfort and economy reasons.
Of course over the years the gears and clutches can wear.
Any potential buyer should check that the gear changes are silky smooth and there are no harsh clunks when selecting gear.
We recommend regular fluid and filter changes.
The manual transmissions are extremely solid. With age, the selector bushings need replacement to rectify sloppy gear changes. Any whining may be indicative of a failing bearing, which would require the box to be overhauled.
Any humming noises from the rear could indicate an issue with the differential bearings. These rarely fail but the noise can dampen the jjoy of driving a W124. Reconditioning of the differential is likely to cost between £600-800.
Suspension
The W124 Coupe shares many suspension components with the standard W124.
Hydraulic rear self levelling was optional on the coupe models. Front shock absorbers are a serviceable item and are not expensive. Various aftermarket options are available.
Front Lower suspension arm ball joints are a wear and tear item that should be checked for excess play. This requires replacement of the complete suspension arm. These should be replaced in pairs. A garage should charge between £7-800 for this work using good quality parts.
The self levelling rear suspension, where applicable, is a little more complex and does require close examination. The pipework should be examined for corrosion. These, like brake pipes, can corrode and leak. The pipes are available from Mercedes, however fitting some of the lines around the rear axle takes time and patience. Rear suspension spheres are a common replacement item which will cause a bouncy uncomfortable ride. These are approximately £200 each from Mercedes. Including fluid and fitting charges, this is around a £600 job. Aftermarket parts are available a little cheaper. Once this job is done, the car should not need them replaced again for at least 100K miles.
The rear shock absorbers have been known to become noisy or leak. Replacement is straight forward but they are pricey. Aftermarket items are around £350 + VAT each.
Due to age, all of the various ball joints and suspension links should be examined closely. The rear lower ball joints in particular are often missed during inspections however they are prone to fail, causing a knocking noise. Special tools are required for this job and a garage would likely charge £300 per side for this work. The five link rear suspension is also worth replacing if it has not had any attention. All the arms/links are available and not too pricey individually, however to complete a refresh of both sides would cost around £800 using genuine parts.
Wheel bearings should be checked for excess play. Front bearings can be adjusted. Rear bearings cannot be adjusted and replacement is a labour intensive job.
Rear subframe bushes should be checked. Deteriorated bushes will cause knocking and will be an MOT failure. Replacement is an expensive laborious job due to the complete axle having to be dropped down.
Steering
Steering is a recirculating ball system. With age and mileage, the steering box can leak or have excess play. Plenty of used spares are available. A recondition will cost around £500-700 with labour.
A ‘wandering’ or vibration in the steering usually means the steering damper is worn out. In our experience, steering dampers normally require replacing at around 100,000 miles or 10 years. They’re relatively cheap and help to regain steering feel.
All of the steering links should be checked. Play in the ball joints of the centre track rod and both outer rods is common but relatively inexpensive to repair.
Brakes and wheels
The W124 uses brake discs all around. The system is generally reliable and the parts are good value from the main dealer.
Brake lines should be checked for corrosion, the rear pipes are difficult to replace as they run above the subframe.
Bodywork
With age, all vehicles will be prone to corrosion. The wheel arches should be examined closely.
Any minor paint bubbles can normally be ground back and repaired.
It is important to examine the car thoroughly for rust, especially on the underside.
We recommend wax protection in order to keep the underside and suspension rust free.
A full respray will run into many thousands depending on level of corrosion, therefore it is very important to check the car over in this respect.
The coupes can suffer with delamination of the rear windscreen. IF this has happened, it is likely metal underneath the window seal may need attention.
Electrics
The electrics on this model do not generally cause many issues. The engine wiring harness is the major concern, which I have mentioned above.
It is important to check the function of every component. Items can fail due to age and although most items are available from Mercedes, prices are not always palatable.
Seats should be checked for all of their functions, electric windows should be fast and smooth. Sunroof should glide back without any nasty noises.
The seat belt butler should deliver the seat belt without hesitation when the door is closed.
The seat backs should lock into position with the doors closed and transmission in drive.
The Air Conditioning system should be examined for proper function. Due to age, leaks in the system are common and electrical such as the fan switches components can fail. The most likely leak point is the condenser, this is available from Mercedes. Cost of replacement will be around £600 from an independent garage.
Indicative Job prices (including labour and VAT):
A service (four/six-cylinder)
£165
B service (four/six-cylinder)
£289
Gearbox service, fuel filter (300CE/E320, 36,000 miles)
£180
Cylinder-head gasket (E320)
£1500
Wiring loom replacement (E320, pre/post 1995)
£750-£1200 depends on options
Water pump and belt (four/six-cylinder)
£600 both similar priced
Front brake discs and pads (four/six-cylinder)
£250/£300
Engine mounts (four/six-cylinder)
£550
Karren Stanly
S Class
I am a kind of person who prefer to read lot of reviews and guide before buying anything. And you know if you're going to buy a new mercedes then you obviously need a best buying guide. Thanks for this.
Roger Simon Newby
W124 CE300 1989 M108
1989 W124 CE300 would not accelerate once the temp got to 85C. We found that the KE-Jetronic airflow valve was not depressing as the ohms were too low. The Bosch solution was a very expensive new or reconditioned Jetronic system. During all the work the radiator was damaged and had to be replaced. On collecting the car from the radiator company, they informed me that the cooling system had been very badly clogged and needed a lot of flushing. Since the engine was flushed the KE-Jetronic system is now working as it should! The engine cooling system must have been so blocked that the heat sensor was no longer working.
Parisien
Fermanagh
SL320 1996, 1990 C124 300ce, 1989 200TE
Great write up, thank you.
P
robbomerc
Shoreham by Sea
W124 E200 and W124 E200
I have just bought an E320 coupe . Love it and thanks for your advice. Proper old school . The steering seems slower than previous w124's but I think the box is different in the 320, mine might be a sportline as it's low with AMG alloys and a wooden gear stick. It's been repainted so the sportline sticker may have gone. Lots of power but also the big petrol tank. I thought something was wrong with the pump as it passed 75 litres as I filled it up. A few detail bits to do but I guess they all do
Bill Mac
r107 350 sl 1977
Hi I am new on here any one got an updated buyers guide for a W124 E320 Cab
have looked at one but there are a few issues not least of which is the seat belt presenters ie how to get at them and strip and repair if required any threads with pics would help
Bill Mac
r107 350 sl 1977
Hi am a neebie and thinking of buying the above any idiots guides to what to look out for apart from the usual ie rust, smokin engine, rough box etc
Oli2Max
London
300 CE 24V (3.0 L M104.98x engine)
this is the first time I'm using the forum and I don't know how it works nor where I should post this. I've decided to try replying to your post as you're obviously an expert. I wonder if you can help me. I have a 300CE 24V 1991 reg which I've had for about 15 years now. Fantastic car but I've had a small leak in the cooling system for a number of years now. I was told it came from the head gasket (car has 293k km). I've used several products to try to stop the leak until I tried the Rislone cooling system leak repair. I knew there was a small risk of blocking the rad especially as it was a bi component product (on part looked like liquid metal). Anyway on the motorway the engine temperature went from 80 degrees Celcius (which is where it normally is) to up to 95 then stabilsed at 90. I thought that's not normal but still way below the red zone. Then the oil light came on and I should really have stopped but I had topped up the oil before leaving and I was only 50km from my destination. Anyway, I blew up the engine and the garage won't have time to look at it till September but I'm pretty sure the engine's had it. There was oil everywhere and the cooling liquid tank was empty. The pressure must have got too much and everything just blew up. Though I didn't not hear anything. The car just stalled. It did restart but then stalled again straight away.
So I'm now looking for a new engine with less mileage. I think I found a couple (one in Germany 160k km and one in the US 87k km). The car is in France right now. It seems I might be able to get the complete engine for around £1,000 . Since I'm going to change the engine I was thinking of putting a bigger one (3.2 3.4 or even 3.6) if I can find one and if the price is reasonable. So my question is: Can I put a bigger engine in the car? My car is a 91 reg so I don't want anything older than that. I think the M 104.980 was made until 1995.
any tips/advice would be much appreciated.
Thank you
Oli
Wagen
Bristol
2006/56 W211 E320 CDI Estate
Wonderful amount of information which will no doubt be helpful to many, thank you for sharing.
A.J.
Norwich. UK
th
TLDR :rolleyes::)
multigrade
1995 W124 E320 M104
Great guide, thank you.
My 96k-mile, 1995 C124 is now 4 months into my ownership and I love it,. The car had been sitting for 5 years, undriven, in a controlled environment before the owner sold it (apparently he owns dozens of Mercs!).
So I've done about 400 miles in it but my plan is to recommission it. The a/c wasn't working due to a leaking condenser which I've replaced - yet to be recharged, fingers crossed it's now vacuum tight - and I'll replace the oil and coolant. The oil was supposed to have been replaced but it looks too black to me, and the filter doesn't look new.
It does have a recent MoT. Hoping there's not much more to be done...
coventryslk
Coventry
W204 CDI Sport
Hi All,
Engine
M102 Engine
M103/M104 Engine
Exhaust
Transmission
Suspension
Steering
Brakes and wheels
Bodywork
I just happened to be looking at 124 coupes recently to get back into Mercedes ownership after selling my w204 in 2020.
