K1100
- Nov 23, 2010
- Location
- Warwickshire
- 1993 320TE auto Japanese import
Hi everyone. I am partway through replacing spheres on my 320 te 1993 and one seized fitting has defeated me. The car is mostly corrosion-free but I cannot remove the pipe to the passenger side sphere, and even though I have used a SnapOn quality flare spanner the nut has rounded off. Before cutting through the pipe I want to be sure I can replace it. MB have the pipe in stock but I am frightened to try to undo the other end at the self-levelling valve in case that end is also seized. I prepared everything with 24 hrs of repeated Plus Gas and so far the valve end also won't loosen off. I can't face putting more pressure on the spanner.
I have seen references to compression fittings that will make possible a joint between a length of the new pipe and the existing pipe but I have Googled every combination of words to find such fittings with no success. Where do I get them?
Thanks.
Thanks.
