crt
- Apr 22, 2005
- '95 E300D estate, '16 Golf, '58 Unimog 404, '95 Defender CSW
I've just fixed a rusted section of SLS pipe on my E300 D estate. While searcing around for tips on how to do this I couldn't find a clear answer to the question of what size the pipe is. The answer is just over 6mm od and around 4.3mm id. I couldn't easily source an exact size in steel (a local hydraulic supplier only had 3mm id), so I made do with copper/nickel. This too was difficult to obtain in 6mm (plenty of copper around in 6mm but not much copper/nickel) and I can confirm that while 1/4" is loosely nominally equivalent, at about 6.3mm od, the Mercedes compression union needed to be bored out slightly with a 1/4" drill to fit the copper sides. It has worked well.
