W124 Two Tone Paint Codes Please
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by Mikesmerc, Jul 11, 2018.
  1. Mikesmerc
    Mikesmerc Senior Member
    929
    5
    Jul 3, 2003
    Co.Cork IRL
    Your Mercedes:
    2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
    Hello all,
    Just wondering if anyone could corfirm paint codes for my car, see pic attached, Im guessing the top is Signal Red 568 and the lower half is Almandine Red Metalic 512
    Shes a 1994 model
    Thanks in advance
    regards
  2. daveenty
    daveenty Senior Member
    2,612
    599
    Jun 21, 2005
    The Frozen North :(
    Your Mercedes:
    2017 W213 E63s & 1989 W201 2.5-16
    Not sure myself, though the bottom half does look like Almandine.
    A definitive answer would probably come from the knowledgeable people over on the 190 Forum. I appreciate that it's not a 190, though there's a lot of owners over there.
  3. OP
    Mikesmerc
    929
    5
    Jul 3, 2003
    Co.Cork IRL
    Your Mercedes:
    Thanks for that, Iv seen pics of 124s with Almandine as the main top colour, just not sure
  4. John Laidlaw
    John Laidlaw Senior Member
    15,641
    3,448
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    Is the plate not still under the bonnet with the paint codes on?
  5. OP
    Mikesmerc
    929
    5
    Jul 3, 2003
    Co.Cork IRL
    Your Mercedes:
  6. OP
    Mikesmerc
    929
    5
    Jul 3, 2003
    Co.Cork IRL
    Your Mercedes:
    Just zoomed in, its 582 imperial red, now I wonder what the lower half is
  7. John Laidlaw
    15,641
    3,448
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Yip agreed 582- Imperial Red. I’ve never seen the plate code for two tone but you’d think common sense would say it would be next to the main paint colour code! This is MB mind
    Mikesmerc likes this.
  8. OP
    Mikesmerc
    929
    5
    Jul 3, 2003
    Co.Cork IRL
    Your Mercedes:
    Put in the VIN to a few of these Decoder sites and all came back with Imperial Red, no mention of the lower half
  9. John Laidlaw
    15,641
    3,448
    Nov 15, 2013
    Wirral
    Your Mercedes:
    That’s what I’m finding as well. Doesn’t seem also from what I’m finding that Imerial was two toned. Almandine yes, other reds yes, and usually with Navarra red 521...or if clad 3521
    As Daveenty says, maybe the specialist forums will reveal more?
  10. John Laidlaw
    15,641
    3,448
    Nov 15, 2013
    Wirral
    Your Mercedes:
  11. OP
    Mikesmerc
    929
    5
    Jul 3, 2003
    Co.Cork IRL
    Your Mercedes:
  12. John Laidlaw
    15,641
    3,448
    Nov 15, 2013
    Wirral
    Your Mercedes:
    It doesn’t- I also looked again at your slam panel plate and above and to the right of the 582 code there is also a code 620. Might be coincidence (I’m no expert I hasten to add) but that comes out as ‘Verkehsrot’ which means bright red. Whilst I can’t find that on Mercedes colour code lists (none that I can find anyway), I found...https://colorndrive.com/gb/touch-up-paint/mercedes-atego-verkehrsrot-3620,84038/details
    Hope that helps and not a red herring! (Excuse the pun)
  13. aybracers
    aybracers Senior Member
    63
    Aug 14, 2007
    London
    Your Mercedes:
    E320 Coupe 1995 + c250CGI
    Code 620 just means that the car has a catalytic convertor fitted.
  14. aybracers
    63
    Aug 14, 2007
    London
    Your Mercedes:
    Here is a list of colour combinations
    COLOR NUMBERS I COLOR NAME I USED WITH OUTSIDE PAINTWORK I
    I------------------------------------------------------------------I
    NO.7700 ALTO GREY I 040 ,122 ,199 I
    NO.7738 SATO GREY I 147 I
    NO.7176 MUSSEL GREY I 172 ,651 ,702 I
    NO.6211 KIWI GREEN I 249C,254 ,261 ,815 I
    NO.6856 TROPICAL GREEN I 249D,256 I
    NO.5301 ANDOR BLUE I 348 ,355 ,900 ,929 I
    NO.8477 CHINCHILLA I 432 ,441 I
    NO.8482 CHIMNEY BROWN I 475 ,485 I
    NO.7166 VIOLETT GREY I 481 I
    NO.3521 NAVARRA RED I 512 ,540 ,587 I
    NO.3515 TARTAN RED I 568 I
    NO.1631 SAFARI BEIGE I 623A I
    NO.1658 LIGHT IVORY I 623B I
    NO.7177 STRATUS GREY I 735 ,751 I
    NO.7181 ATLAS GREY I 744 ,752 I
    NO.6250 LAGO I 888 I
    NO.5309 RIO BLUE I 904 I
    A = UP TO IDENT NO.: B 365987 I
    B = FROM IDENT NO.: B 365988 I
    C = UP TO IDENT NO.: B 431235 I
    D = FROM IDENT NO.: B 431236 I
    So 3515 Tartan Red should be the colour to go with Paint code 568
  15. John Laidlaw
    15,641
    3,448
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Good info
  16. John Laidlaw
    15,641
    3,448
    Nov 15, 2013
    Wirral
    Your Mercedes:
    But the op has 582 Imperial which is the confusion
    Hopefully he’s got on better on a specialist forum for 124s
Share This Page
