W124 Water Drain unblocking
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by d215yq, Aug 7, 2012.
  1. television
    television Always remembered RIP
    164,084
    260
    Your Mercedes:
    I have sent it Mike.
  2. speedyw124
    speedyw124 New Member
    7
    Mar 29, 2014
    Your Mercedes:
    W124/1991/230TE
  3. Richie644
    Richie644 Guest
    Hi Malcolm,
    Do you have anything for the R171?.. I've found three drains in the water catcher (front screen), one in the battery compartment, 2 in the boot from the rear of the tin top (these are easy, just disconnect and blow through).. So i know where the entry points are, just could do with exit points??
    When car was last MOT'd had a look underneath when on the ramp, found 2 drains, one either side of the prop shaft/gearbox, haven't a clue where entry points are for these!!
    Any help would be much appreciated :)
  4. jst_at_home
    jst_at_home New Member
    Jan 25, 2017
    Lancashire, UK
    Your Mercedes:
    W124 300E-24 1991 3000
    On the assumption that Wireman is still here somewhere, many thanks for the info regarding the drains. I couldn't have cleared it without your photos.
  5. Grahamkendall
    Grahamkendall Active Member
    29
    Jan 15, 2017
    Glasgow uk
    Your Mercedes:
    1983 W123 230e
    Not sure if its any use here, I also have a Discovery 3, the sunroof drains block very frequently, similarly on my old R170 SLK the scuttle drains used to get blocked. For each of these I have always used a large length of curtain wire. It has never failed to work.
    I tried compressed air once as well. That didn't end well when it over pressurised and ruptured a blocked tube
  6. Roy Lavis
    Roy Lavis New Member
    Jun 7, 2018
    Your Mercedes:
    w124 e250 1995
    Any one know where I can buy part 1244710681 online? thanks.
  7. rayhennig
    rayhennig Senior Member
    438
    17
    Nov 16, 2006
    Your Mercedes:
    1991 300CE-24 Sportline
    Yes, here:
    https://www.teile-profis.de/page_1_3.php#oeformo
    But it would make sense to order some other items at the same time to justify the €14 shipment costs.
    RayH
    Roy Lavis likes this.
  8. Roy Lavis
    Jun 7, 2018
    Your Mercedes:
    w124 e250 1995
    Hi Ray, Thankyou for your reply, I will take a look at this. As you say shipment cost do not justify the part cost but I will see what else I need.
Share This Page
