horatio
I have replaced the engine mounts with Lemforders, fitted new spark plugs (NGK non-resistors) and removed/cleaned the throttle body.
Disconnecting the MAF at idle makes no difference at all (?).
It drives really well and idles nicely at 700 ish. I can't see any obvious vacuum leaks.
Any thoughts on what I can check before admitting defeat and booking into an Indy?
Cheers!
Cheers!
