EdGasket
I have been getting knocking sounds from under the centre consol when pulling away and when putting max power through the drivetrain. The front flex disc has been replaced and the rear looks OK. On wiggling the prop shaft and looking along the heat shield from the back, it looks like the propshaft centre bearing has parted company with its rubber surround.
I would like to know:
1) How long can I continue to drive it in this state; seems to run fine apart from knocking sometimes in first gear? Will this damage the prop if I continue to use it?
2) Has anyone tried an on-car repair using Polyurethane Adhesive Sealant to patch up the rubber surround?
3) The four fixings on the heatshield underneath the bearing look rusted out. Is it of to leave that heatshield off or if not any ideas on how to re-attach the heatshield assuming the fixings are toast?
4) Any idea how much a centre bearing job would cost to have done? Looks like the exhaust has to be dropped and a bit of a PITA job all round as I have to work outside and the car is an Esprit which means it is lowered and difficult to get under even on car ramps.
