W202 Engine Mount Part No.
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Woody123, Aug 12, 2018.
  1. Woody123
    Woody123 Senior Member
    59
    10
    May 7, 2018
    Your Mercedes:
    C200 1998 2.0
    Hello everyone.
    Having a hard time tracking down engine mounts online.
    Car is w202 1998 C200 manual. I usually use euro car parts but it’s not showing me three mounts (left right gearbox) by the same manufacturer. Two are Hutchinson and one is corteco. Do I really need lemforder?
    Does anyone have the three part numbers I need for each mount? It would be just my luck to order the wrong ones.
    Failing that anyone know good OE parts supplier number I could call?
  2. brianbrian
    brianbrian Senior Member
    2,456
    72
    Sep 27, 2008
    cockney in the West Country
    Your Mercedes:
    w124 250D, SL129-deisel
    Just give Mercedes your chassis No,you will get the right ones then. Not that expensive.
    Woody123 likes this.
  3. Severnless
    Severnless Active Member
    37
    17
    Jan 12, 2018
    West midlands
    Your Mercedes:
    E320 CDI/2007/v6
  4. AMck
    AMck Senior Member
    834
    6
    Jul 3, 2008
    Newport
    Your Mercedes:
    2007 E320cdi S211, SL320 2000(written off), 2007,Volvo C70 D5, 1976 Ford Gran Torino, 1978 VW camper
    To get your part numbers Lemforder have an online parts catalogue - https://webcat.zf.com/?SPR=4
    They also have an app you can put on your phone.
    Oldspanners and Woody123 like this.
  5. OP
    Woody123
    59
    10
    May 7, 2018
    Your Mercedes:
    C200 1998 2.0
    Thanks for the help lads.
    Gonna have a crack at doing the 3 engine mounts myself, doesn’t seem too intensive but I’ve never done it before
  6. brianbrian
    2,456
    72
    Sep 27, 2008
    Your Mercedes:
    If you have not changed a engine mount, before , make sure your drive and socket are firmly on, and as you draw the bolt out it does not full out the socket.
  7. OP
    Woody123
    59
    10
    May 7, 2018
    Your Mercedes:
    C200 1998 2.0
    I’m guessing you’re speaking from a bad experience?
  8. brianbrian
    2,456
    72
    Sep 27, 2008
    Your Mercedes:
    I remember most mistakes, 20yrs ago as I drew the drive and socket out, the bolt came of the socket and fell in the chassis. Spent 30 minutes to retrieve it.
  9. OP
    Woody123
    59
    10
    May 7, 2018
    Your Mercedes:
    C200 1998 2.0
    I had to peel the bumper off my mondeo once to rescue a very needed socket from behind the headlight. I feel your pain
  10. OP
    Woody123
    59
    10
    May 7, 2018
    Your Mercedes:
    C200 1998 2.0
    I’ve tracked down the parts on the website..
    Of the three mounts: One says left/right, one says rear and the last one says left only.
    I am aware that both sides are different and won’t take the same mount? So I’m guessing the one that says left/right means right?
    Also does it matter that mine is manual and it says it’s for an auto?
Share This Page
