KOMPRESSIT
- Aug 26, 2009
- Location
- SCOTLAND
- 1996 C230K , 2006 E320cdi
Hi Dec,
I lifted the fuse box and made sure all wires were pushed fully home on the other side - everything seemed Ok. (But the fault still exists, but just noticed last time I tried it that the full-beam 'flash' light works - when you pull the stalk to 'flash' your lights). I think I'll check a few more 'feeds' to the cluser before being 100% sure it is the cluster pcb that's at fault.
This has been a nightmare to try and solve, I've owned 9 or 10 cars and never had anything like this go wrong. I'm fed up - spent most of the weekend on it, so I think I'll leave it for now and have a think about it tonight.
Where I am at the moment = I'm not 100% convinced it is the cluster PCB (probably 60%) and the other 40% I think it could be 'supply' related, but it is difficult to test due to not being able to turn the ignition on with the PCB removed (due to airbag light would need re-set). Perhaps you are right - I'll think about the diagnostics option.
Thanks for all your advice Dec I would never have got the cluster removed from the car or even got checked what I did without your help.
I'll study the wiring diagrams tonight again (helps me get to sleep) to see if I can think of anything.
Thanks again Dec,
Kompressit
Thanks again Dec,
Kompressit
