W202 Oem Xenon Conversion
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
I have just sourced a pair of Genuine OEM xenon headlights for a w202, though i believe the the headlights are a direct exchange with my originals (as the original MB Units have the ballast/ignitor packs fitted on the headlights themselves), but as i want to do the conversion properly i need to know how the headlight auto self levelling system operates on a w202, when fitted with xenons from the factory.
The existing halogen set up is only adjusted manually via a dial adjacent to the light switch, and i always believed the xenons recieved an input from a unit above the diff, and required the diff to be removed to fit it, but i cannot find this unit on the EPC i,m using chassis number from C43's (one with xenons, one without).
Can anyone shed any light on this? (forgive the pun) Any info greatly appreciated.
colechelle
Resigned
i will look on WIS for you andy,see what i can find!!
whitenemesis
CLS55 AMG '05
Hi Andy,
The 202 is the same as the 203 in that the xenons are levelled using sensors to the front and rear suspension. This is a genuine retro-fit option
So you will need the auto levelling loom and the two sensors and the headlamp range control unit (this later part is integral to the headlamps on the 203 but not on the 202)
The doc I'm reading also has the ballast seperate from the headlamps? (202 as of 1.6.97)
Andy,,I may have the retro fit for you,,if I have you can PM me on either miss D's computer or yours:rolleyes::cool:
I have 2 papers on the retro fit, please PM me with your E mail address
If you need more papers just ask and I will think about sending them;-);-)
You have to remove a rear spring to fit the rear adjuster
bigasotonuk
bigasotonuk
Southampton UK
Many thanks will look forward to seeing what you can find.
Whitenemesis has told me that there are 6 papers,,if you need the others they can be sent
bigasotonuk
bigasotonuk
Southampton UK
Hi Andy,
I have been looking on the official MB EPC with 2 C43 chassis numbers (one with xenons, one without), and it appears that the sensors i already have because its seems they utilise the existing ESP sensors, even the loom that has the plugs for the headlight level motors 1 at each light appear according to the EPC are already fitted to my car from the factory.
Lets hope this is the case fingers crossed.
whitenemesis
CLS55 AMG '05
This is what I have found. The sensors are the same as the ones I had fitted.
whitenemesis
CLS55 AMG '05
A neat solution to the levelling but Andy wants to do the proper conversion, well he did. Perhaps he will change his mind now! :D
I too cant see him going all the way, it is a massive job on the rear end
bigasotonuk
bigasotonuk
Southampton UK
I do want to do the job properly but i may change it over till i get the auto levelling sorted.
I,ve got the headlamp wash/wipe system coming too.
He said he would remove all the wiring for me aswell as the axle sensors, but to be honest i,m expecting to have to buy some parts.
so am i right in thinking the headlight levelling is done via 1 sensor on the front and 1 on the rear?
Whitenemesis, did your car have ESP? as from the EPC it appears the levelling is fed from the ESP sensors on my car. I,m just wondering if the sensor(s) only had to be fitted with cars without ESP.
Though i,m probably reading the EPC wrong.
whitenemesis
CLS55 AMG '05
Yes my car has ESP...
And yes, one sensor each axle.
The sensors measure the degree of suspension travel, nothing to do with ESP which is to do with wheel rotational speed.
If you PM me your VIN I can be sure I have the correct info.
I sent the correct C43 papers that tell you the best part
56kb and 91kb they do take a bit of time to go through but he should have them by now
bigasotonuk
bigasotonuk
Southampton UK
  • #18
Still no mail Malc, just recieved an e-mail from e-bay so i,m presuming its ok at my end :confused:
Nothing come back and nothing in my out box,,I will send them again by just copying your Email address
