My C180K is amazingly still running on it's original Merc battery (15yrs old). I've ordered a new battery and was going to change this myself, until I read several threads warning about blowing SAMs when changing batteries, giving instructions on keeping power to the vehicle with a slave.
I recently changed by PCV pipe and as part of that job I disconnected the negative lead (which was the first step in recommended in the Haynes manual). I had no issues when I reconnected the lead.
So I'm curious, what's the difference between a battery change and removing a lead from the battery when doing any electrical work on the vehicle? I can't believe you have to keep power to the vehicle at all times - what if you were changing an airbag, for example?
Thanks for any answers. Car is going to my local indie on Friday for other things, so I'll probably ask them to change the battery now, but would like to know peoples thoughts on this.
