W203 C180K misfire
Tomkinsm
Hi all,
My W203 C180K has started to misfire on start-up. It's been happening, occasionally, for a few months, but now becoming more regular. It will misfire and run lumpy, I turn it off and restart and it runs fine. Once going, it seems to run fine as normal. It throws up the engine management light sometimes, but not always. The most recent codes I read using a generic reader are:
P0303 cylinder 3 misfire detected
P0302 cylinder 2 misfire detected
P0172 system too rich (bank 1)
I replaced the plugs, air filter and fuel filter. It didn't fix the problem.
I wonder if it's a coil pack issue, or something more complex. I realise this could be many things, but if anyone has some suggestions it would be helpful and much appreciated.
Diddles
C class 2007 1.8
Could be crank case ventilation hoses split. Does the engine hunt when cold?
T
Tomkinsm
Sometimes, but not often. But it's a good suggestion, I'll check the hoses, thanks.
T
Tomkinsm
Finally got around to looking at this. The crankcase ventilation hose was indeed split. Not a nice job but I managed to change it and felt optimistic I'd solved it....
But car is still not right. Exhaust smells rich and takes a long time to start when hot. Cold start is fine and car seems to drive ok though.
Any other ideas? I wonder if I should have changed the MAF when I had the airbox off.
Oldspanners
Normandy
C CLASS 2004 C180
It may take a while to re
It may take a while to re-learn the new settings.
Was there a lot of oil in the intake?
Other problems may be the O2 sensors but that will throw up codes.
Oil leaking into the wiring harness if blockers haven't been fitted at the cam magnets.
Cam chain and sprockets worn.
Diddles
C class 2007 1.8
20180428_134204.jpg That top crank case ventilation pipe does go into a valve and then another pipe which also fail and split.
They are harder to get to, I did mine while I had the head off so was easy, but normally it's intake manifold off and kompressor out the way.
T
Tomkinsm
Thanks for suggestions.
There was some oil in the pipe between the airbox and the compressor but the inside of the elbow of the airbox looked dry.
Yes I read about the valve and the second pipe. I think that job is beyond me...at least I don't have the time.
It's almost as if the car thinks it's cold and applies a choke or rich mixture even when hot. Cold start is perfect. Temperature sensor looks ok though, engine temp on display seems normal. I guess I need to get a proper diagnosis, my generic OBD reader is probably a bit limited.
Any idea how long (or miles) it takes to re-learn?
Oldspanners
Normandy
C CLASS 2004 C180
With mine it varied depending on what sort of journeys I did, long, short, fast, slow. On the OBD reader I have it will show when all sensors are back on line either by a LED changing from orange to green (or red if the problem re-occurs) or by reading their state.
The problem I had was oil wicking into the wiring harness and putting the after cat o2 sensor off line but it certainly made the mixture rich reflected in the exhaust and obviously MPG.
T
Tomkinsm
How about the intake air temp sensor - I assume there is one? Would explain why it's only happening when hot.
Can anyone tell me where it is please?
If you have live data on your code reader it should be able to show the IAT.
T
Tomkinsm
It's now nearly a week since I changed the PCV hose and the good news is that I've had no misfires and there are no fault codes coming up. So I think thats solved at least the initial P0172 and misfires.
...But the engine is still taking a long time to start when hot. It never fails to start, but cranks over a lot before firing. IAT and engine temps all look normal on the code reader.
I found a number of reports of other engines with hot stating issues where people pointed towards the crankshaft position sensor. Would this also cause a hot starting issue on the M271 engine?
CPS failures usually mean no start when hot.
T
Tomkinsm
I never gave a conclusion to this thread, sorry. But here it is, if it might help anyone in the future:
The PCV hose was split and was replaced. It made an improvement to the misfires, but not the hot starting
In the end I took it to my speciallist, who diagnosed a dodgy fuel filter (non Merc one I had fitted), and still a fault with crankcase breathing. They replaced the fuel filter and changed the PCV non-return valve and lower pipe.
Hot starting is fixed, car performs better and average mpg is much better +5 on average.
Conclusion 1: Use original filters!
Conclusion 2: I don't recommend trying to replace the top PCV valve yourself because it's a fiddly job and chances are the lower parts need changing too - bite the bullet and get all hoses and valve changed at once. Supercharger out makes it a difficult DIY job, but my Indie did it and I was happy to pay the money.
I wish I'd had the supercharger oil changed whilst it was out, but thats another story..
I changed my supercharger oil myself a while ago , £20 for oil on eBay with a syringe , easy 1 hour DIY job . I have done a thread on it somewhere .
Glad the rest is sorted , thanks for the update buddy , it always helps others in the future .
T
Tomkinsm
Thanks Wighty,
Did you do the supercharger oil in-situ? I'll try to find your thread, will be useful for the future.
Thanks Wighty,
I got my info from some YouTube threads on Mercedes supercharger oil change . I bourght some supercharger oil from eBay (most sellers now sell a syringe and tube with the oil)
Other than removing some plastic ducting from the front of the engine and buying some long torx tools that was about it . It is fiddly getting the small tube into the back lower end of the supercharger oil reservoir, but once you hit the sweet spot I left the tube in position and detached the syringe each time it was full before squirting the old oil into a container . Filling was just a case of letting the oil dribble out the hole .
Pack a rag below the small sump bolt so you can't drop it into any of the engine recesses below where it is .
I'm not sure if you can buy them seperately .
Make sure that you don't get the oil on the engine belt either .
I've just checked and I don't think I did a thread on it . Damn my poor memory ! But I did change it :D
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
You did, I remember reading it and thinking that I'd do it when I got to 70/75 000. Perhaps it was in "What have you done to your Merc today"? Nice tip about the sweet spot.
Good memory buddy :D
