W203 - C220 CDI - Fuel Pump & Pipe Leaks Help
Alex Crow
Super Suffolk
i think they come with the new pipes, could be improvised with something i would think.
Rappey69
hants
c220 w204 amg sport
i too thought i had a fault with my high pressure pump as diesel was leaking out and running down the block..
i bought new pipes which has all the seals on it and once replaced all the leaks stopped !
towack
New Registration
Hi Rappey
where did you get your pipes from?
Rappey69
hants
c220 w204 amg sport
I bought them from a proper m/b dealership at around £45 for all of them.
HelpThisDude
Essex
W203 C270CDI, R172 SLK55 AMG
Hello Rappey69, did you have to give them all the part numbers or were they OK doing all the searching?
HelpThisDude
Essex
Oh and anyone know the torque for the screw that holds the pipe O ring clamp on to the pump? (item no. 101 in the diagram on original post on page 1)
Cheers :)
Rappey69
hants
c220 w204 amg sport
all i did was go into M/B stealership parts dept, and tell them i want all the plastic fuel lines that are under the bonnet.
they looked them up (they wanted vin number).
Check that the ones they give you match the ones under your bonnet as they got it wrong first time round :(
as for part 101, its only a clamp plate that holds the two plastic pipes in place so a sensible tightness for that sized bolt should suffice as rubber will take up until plate cant be pulled up any tighter.
timcarr
ABERGELE
W203 C270 ESTATE
hi all,first of all a BIG thanks to wullyuk for his in depth posting on this subject. I have an '02 C270 cdi that had the same fault on the high pressure pump (leaking valve cover plate) and i didnt really relish the thought of forking out £280 + vat for an exchange unit,initially i phoned my local mercedes dealer asking if seal kits were available and was told no only exchange pumps were. So after reading this i managed to bully the parts man at the dealer to order me the said kit (must be a BIG profit margin with the exchange pump). removed pump and set about replacing seals under valve covers (you have to be clinical in your cleanliness whilst doing this also the mating faces suffer from surface corrosion which you have to remove with wet and dry.So job done and no more leaks ! while i was at it i noticed the lower fuel pipe entering the low pressure pump was letting air in so i replaced the 'o' ring at the end of the pipe and this seems to be ok now too (air in the system causes poor starting).thanks again wullyuk.
Danny&Andrea
Swansea
C270CDI Avantgarde SE Estate
I've just broken down due to the same problems listed above. However my leak has just caused alternator belt to snap, so im completely immobilised now.
The AA are on there way to tow it to the garage that was supposed to fix this fault 2 weeks ago. Damn Christmas period lol.
Is it safe to say that i only need the "O" rings replaced to cure the leak?
Im not a dab hand at anything practical, but that the parts i had the garage order along with alternator belt.
Cheers
Rappey69
hants
c220 w204 amg sport
There is also a foamy type washer that sits between where the pipes join the high pressure pump.
Its not much to get whole new pipes as some say the clips can become brittle and snap.
£280+vat for pump (eek) Dont know if its the same as the 220 but that is not much over £100 from eurocarparts.
philn826
Burton on Trent
Mercedes C220 CDi & BMW 330DSE
mercedes c220 cdi fuel pump leak
Hi all,
This is my first time on this forum so bear with me..
I have a similiar problem as WULLYUK with a a fuel pump leak...
My pump has two leaks;
First leak is at the the top of the pump, where bolts 27 hold the top down (I presume there is some sort of gasket between top and main body of pump)
Second leak is from the same type of plate which is on the right handside of pump as you look at it...(again is there a gasket here)
Questions I want answering if possible are:
Am I able to just remove fuel pump from car or are there any switches or procedures in removing it?
Secondly am i able to buy the gaskets which I think may be the cause of the leaks.
Thirdly - Diesel has leaked onto the drive belt, will this need replacing too?
Thanks Phil
Danny&Andrea
Swansea
I had 2 "O" rings replaced yesterday finally. Car starts fine now in the mornings :D
Yes alternator belt will need replacing mate.
alanthebig
E320cdi W211
checked the link and the pictures both are no longer available
any chance of supplying the pictures and the link again
Many thanks
Alan
nas786
New Registration
UK - England
Mercedes W210 E320 CDI Avantgarde 2002
Apologies for reviving the thread but I have a similar problem with my 320 engine.
I have the W210 E320 cdi 2002, diesel is leaking from the top of the pump where bolt 27 lives. Any one know if there's a seal or gasket I can replace?
Cheers
jj1975
essex
w203 c220cdi 2002
hi every one I do have 52 reg C class 220cdi and same problem leaking from around fuel pump it happen just after i changed the thermostat dont know why I would to know if anyone can answer can fuel pump 'O' ring stop the diesel from leaking ?
turbospud
i changed my thermostat and the pipe with the test tail that passes the thermostat was very brittle and cracked when moved,ma612 070 3232 is part no £24 from merc
jj1975
essex
w203 c220cdi 2002
Edlosoldier
Doncaster
Mercedes c270
Part 89
Hi i know this is a old post but does any1 no the part number for 89
