charl39
- Jan 22, 2010
- Location
- Oxford
- W203 C270CDi (02 reg); too many Alfa-Romeos
Morning all
I have an intermittent problem with these warning messages. My 2002 C270CDi (151,000 miles) is otherwise brilliantly reliable, but over the past few weeks I've had the problem of these warnings going on. What happens is this:
Does anyone have an idea of what actually might be the cause of this? Or alternatively, of a workshop in the Oxfordshire area who are any good at this sort of thing?
I love my car and am very reluctant to replace it. I could never replace it with the modern equivalent anyway - I just can't afford that any more. The MOT is due in March and I obviously need to sort it out before then.
Thanks for your collective wisdom!
- First of all the EPC and BAS warnings go on, a few minutes after starting the car in the morning.
- Next, after about 10 miles, the ABS and ESC warnings go on.
- All four of these warnings stay on every time I start the car. The cruise control doesn't work either (but the autobox does change gears just fine.)
- I take it to my local (independent) garage to look at it. They scratch their heads, try to reset the codes, which doesn't (apparently) work, and I take the car away again with the warnings still showing.
- Miraculously, the next time I start the car, the warnings have disappeared, and stay off, for about a week. Then it happens all over again.
- According to the garage, it could be a faulty sensor encased in a ring in the rear wheel assembly. The part itself is cheap, but they say tha to fit it, the driveshaft has to come off first, which risks damaging it.
