Paul Goff
- May 17, 2017
- 2002 C220CDi CD Estate
Yesterday my 2002 W203 CDi220 threw it's auxiliary drive belt, no big problem, I put a new one on, checked it visually while running and tested the charge voltage with everything switched on. All OK
BUT the big red warning message on the display won't reset!
My owners manual makes it clear that I should be able to reset it and says how to do so, however the car has other ideas, so I haven't been able to do this.
Did a search here, and it seems that disconnecting the battery for a couple minutes could clear it. That's fine, can do that but am a bit wary of stirring up other problems with modules etc if I do, or do so incorrectly!
Is it better to just leave it, or disconnect away? If the latter, is there a specific procedure other than the usual negative off first/back on last?
