-Had accident, outer door/skin, glass and wing mirror were replaced.
-Could hear wind noise at 70mph+ and became apparent the door wasn't fitted properly
-Passenger side door absolute silence
-Outer door/skin and seal has been refitted- looks fine now.
-Still got the wind noise, albeit not as bad (it couldn't have got worse given the original repair)
The repair is no longer under warranty
I originally had a lot of problems getting the door aligned correctly. Eventually it was aligned properly, but by this I mean in terms of visual correctness. I am not sure if there is still some minor misalignment causing the problem (I assume there is a very small tolerance for fitting correctly otherwise you get the wind noise).
How can I locate the source of the problem further? I was going to purchase a digital sound meter and try establish exactly where the noise is. It seems to be located towards the wing mirror but I **think** there was also noise in the middle of the window.
One thing I never originally considered is the replaced glass might be too thin and it's not sealing.
The outer door seal seems to be well-fit down the A pillar.
I also read sometimes this problem is caused by the wing mirror not being fit correctly.
I assume I will also have to try the masking tape trick and see if that makes a difference?
Are there any photos I could take to help the forum make suggestions?
Any help greatly appreciated.
