starrzo
Hi guys,
I am hoping for some advice.
I have had my w204 2009 C220 CDI (pre-blue efficiency) OM646 for around 5 or 6 months now. It has been a great car. I noticed when I got the car that it had been running cool so I replaced the thermostat and now the temp sits perfectly at 95 degrees.
There has been one other issue - very occasionally (around 5 or 6 times in total since I have owned it) when the car is idling at traffic lights or waiting at a junction there would be some vibration/rumbling which would go away once the car started moving again. I put it down to possibly worn engine/gearbox mounts, however:
About 6 weeks ago I got a yellow engine warning light - no other symptoms. The warning light disappeared after 3 engine starts and nothing since. This morning, I got the light again. I purchased a cheap OBD2 bluetooth reader from eBay a couple of weeks ago, and I managed to pull the code just now: P0340 - Camshaft Position Sensor "A" Circuit Bank 1 or Single Sensor.
Out of interest, I just restarted the car 3 times, and the engine light has gone again.
So my question is; is it likely that I have a faulty sensor, or is it possible that there are other more serious issues? What should I do now?
I was tempted to run out to the dealer to get a new sensor and try to swap it, but I thought I would get some advice on here first. I have attached two pictures for reference, one of the fault code and the other of the sensor.
Thanks in advance.
Thanks in advance.
