markwightman
- Jul 7, 2014
- Location
- Linlithgow
- W204 2008 C Class Kompressor Estate
Ever since I bought my C200 it has displayed the following odd behaviour. Every so often:
- The temperature gauge drops to zero
- The engine fan comes on
- The heater comes on.
If I pull over and switch off the ignition and then switch on again everything returns to normal.
This used to happen typically if I was driving at higher speed, say on a motorway, and slowed down, e.g. came off the motorway. It also used to be relatively infrequent, like once every couple of months or so.
Now it is getting more frequent happening several times a week, and even multiple times in a day. It also happens shortly after starting, and isn't associated with the fast/slow thing anymore.
Also, on a few occasions recently, the yellow engine warning light has been coming on and staying on when the temperature gauge thing happens. If I leave it switched off for a few hours the warning light returns to normal.
I had the temp sensor replaced a couple of years ago but it made no difference.
Anyone got any ideas what could cause the combination of symptoms described above?
Many thanks.
Many thanks.
