W205 2019 Audio 20 entry level Sat Nav
staylorhome
Is there anyway of importing speed cameras into the entry level Sat nav on a new 2019 model c class
I don,t thinks its the Garmen Sat Nav and its not Comand
wivenhoe
Colchester
2018 E Class E350e plug in hybrid
Comand is now a definate no. I would ask PocketGPSworld https://www.pocketgpsworld.com/modules.php?name=Cameras&referer=SideBar
I used them for years with Comand and found them to be accurate and regularly updated. As you’ll see, they provide files for most systems and ar3 very helpful. Good luck as I suspect MB may have closed the function of importing POI’s as they have on the latest Comand
staylorhome
staylorhome
Thanks for the reply, i suspect so as i cannot see even where you would import them
wivenhoe
Colchester
On previous Comand's you had the cameras as POI's on a SD card which on C is in the port in the central arm rest compartment. Have a look at the sat nav menu and see if there is an import POI facility.
I have given up trying to import them into my Comand - I use Waze in the background in CarPlay and this warns over the speakers - not as elegant as having the cameras displayed on the map but better than nothing.
