W208 Auto gearbox Dipstick
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by seanrgb, Aug 20, 2017.
  1. seanrgb
    seanrgb New Member
    7
    Nov 21, 2015
    London
    Your Mercedes:
    W208/2002/2.3
    Hi Everyone
    I want to change the Filter and the ATF in my Clk I have noticed that you can get a Dipstick from ebay but there seems to be different sizes any idea's on which one is right for my car which is a 2002 230 CLK
  2. Wighty
    Wighty Senior Member
    3,136
    1,036
    Aug 4, 2016
    Your Mercedes:
    Search for 722.6 dipstick , they are always too long for the dipstick tube
  3. mercman111
    mercman111 Senior Member
    168
    Nov 13, 2015
    ledbury
    Your Mercedes:
    2003 clk 270 cdi
    or as malcolm says (rip) a piece of flexible curtain wire and put a mark 7cms from the tip
  4. umblecumbuz
    umblecumbuz Senior Member
    2,964
    412
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    Personally, I would ignore the curtain wire tip.
    I have tried it, and trying to see the exact level is a real pain, and subject to error.
    The correct gearbox dipstick, on which the level is clearly read, is only a few pounds, so why skimp and risk fudging the job for so little?
  5. Arudge
    Arudge Senior Member
    753
    238
    Jun 14, 2016
    Cradley Heath
    Your Mercedes:
    CLK200 2000 Kompressor
    I use a piece of clear tubing. Push it to the bottom, put your thumb over the open end and pull it back out. Gives a very clear reading.
  6. OP
    seanrgb
    seanrgb New Member
    7
    Nov 21, 2015
    London
    Your Mercedes:
    W208/2002/2.3
    Cheers Everyone
  7. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,222
    536
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Mercedes-Benz C32AMG, SL55AMG, C320CDI Sport Edition Estate and SLR McLaren Coupe Roadster.
    If you are just changing the sump pan then that only holds 3.8L.
    If you are bleeding the TC, then it takes 6.5. Just measure the oil you drain from the cooler pipe and replace the same amount down through the dipstick tube.
    Of course having the dipstick is preferable.
    GlosRichCLK likes this.
  8. GlosRichCLK
    GlosRichCLK Senior Member
    192
    44
    Aug 18, 2017
    Gloucestershire
    Your Mercedes:
    2012 W212 E350 CDi Sport saloon and previously a 2001 CLK 230 K Cabriolet A208
    Hi Steve,
    So these service kits you see on Ebay for the 722.6 5 speed auto, why do they supply 8 litres of oil? Are they just a rip off.
    I'm thinking of doing mine before winter.
    Is it acceptable to just drain the sump, not change the filter and then refill with new fluid? Just thinking that might be easier for me that taking off the sump pan also.... are the sump bolts a really high torque?
    Is vacuum extraction through the dipstick tube possible, as I have one of those Pela extractors?
    Thanks for any advice.
  9. Steve@Avantgarde
    6,222
    536
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Hi Rich.
    1. Dont know about the service kits... I don't buy them from eBay personally, all my gearbox stuff is supplied by MB.
    2. If you just drain the sump without removal you will only drain about 2L in total...pointeless if you ask me. If you are confident in your ability and have the right tools its not a hard job, even for a novice.
    3. I wouldn't vac extract a gearbox sump, you have to drain the sump to change the filter anyway...
    4. The bolt torque for the sump bolts is 8nm and 25nm for the sump bung.
  10. GlosRichCLK
    192
    44
    Aug 18, 2017
    Gloucestershire
    Your Mercedes:
    Thanks Steve, good advice.
  11. Wighty
    3,136
    1,036
    Aug 4, 2016
    Your Mercedes:
    I have regularly used my Pela to suction out ATF from the dipstick tube , but I have only done it when the filter has been recently changed and I haven't done a full flush of the TC and hoses . I recently did the filter change myself which went ok and I may suction out 3.5 litres in a few months and replace it with some fresh stuff . I use Fuchs atf4134 from eBay which is a pretty good price and is 236.14 spec
  12. GlosRichCLK
    192
    44
    Aug 18, 2017
    Gloucestershire
    Your Mercedes:
    Do you check the fluid level when the engine/trans is hot or cold?
  13. Wighty
    3,136
    1,036
    Aug 4, 2016
    Your Mercedes:
    Hot after 20 min drive , level surface , engine running , gearbox in Park .
  14. GlosRichCLK
    192
    44
    Aug 18, 2017
    Gloucestershire
    Your Mercedes:
    Will have to change my connector plug also as I have some transmission oil under my passenger carpet. Transmission ECU looks fairly dry still, only a bit on the cables.
Share This Page
