W210 Crank timing marks
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
is this correct? Can't see any other marks to line it up with.
bob 6600
bob 6600
  • #2
Just in case it helps anyone a small update. This IS the timing mark however when the marks line up it should be at TDC. Not in my case as the marks on the camshafts were no where near. So I aligned the cams and the crank mark was approx 30 deg to the right. Possible that the belt on the crank (with the timing mark) was fitted incorrectly or has been moved.
Never time to a belt. The timing marks are always on the metal body of a pulley.
star
Reading
Smart + others :)
Some engine ARE timed up not on tdc ie. 30 degrees after tdc
