Stagman
Advice please. My 1998 105,000 miles E300TD estate has recently been reverting to 'limp home' mode. However, when it does this there are no warning lamps illuminating on the dash, just a lack of power; kicking down will facilitate the gearbox to change down, but there is no / little increase in road speed - bearing in mind the RH pedal is buried in the carpet, just an increase in revs corresponding to the downshift. If the engine is turned off for a few seconds, then upon restarting, all appears to be back to normal until the fault decides to manifest itself again.
I took a trip to my local indy this morning to have the fault codes read, but the car behaved normally. Consequently once there I was told, that with no fault present and no engine warning lights, it was no point in connecting the car up to read the fault codes as none would be recorded.
I don't wish to randomly look at / clean / change components. However, from my research on the forum etc. I am thinking it may be an EGR fault, but would welcome views from others before I proceed further. Is disabling the EGR the way forward? Or can someone guide me through a systematic set of tests that I should follow to establish what needs sorting.
Thank you.
Thank you.
