bob 6600
- Dec 21, 2010
- Audi S8 V10, S210 E320 CDI (R.I.P.)
Well the W210 is back together (not completely) but enough to do a test start. So I turn the key and...nothing. Well almost nothing, I have ignition lights and key turns but that's it. Checked my connections and they are all ok. Turning to fuses, the 4th fuse (7.5A) on the K40 p/n A0005400372 is blown. Annoyingly, this also powers the diagnostic socket on pin 2 so I cannot connect it to STAR. I replaced the fuse and it is fine until I try turning the ignition on and it blows straight away.
My first thoughts are near the starter motor as I had to disconnect the -ve feed as it goes through the manifold. I know it was definitely all connected but will check tomorrow. I know the K40 can also be troublesome but it seems to be this fuse. Anyone know what is causing this or what this fuse is for? It's the 4th one along, the first 7.5A.
After days of work I am gutted that it won't even turn over!
