SHAMGIT
w211 220cdi estate 58 reg,198000 miles,all wheels are balanced,gearbox mount changed 40,000 miles ago, still original centre prop bearing,original doughnut ,the engine mounts have not been changed there is no vibration from the engine on tick over and the mounts are not leaking,
new atf and filters 15,000 miles ago,
problem started with minor vibration which wheel balance didnt cure, when vehicle is cold no judder,when hot vibration gets worse,68mph to 73mph quite bad,take foot of accelerator and it disappears,on a hill under power at 30mph judder is quite bad possibly in 3rd gear,
ok guys is it going to be lock up valve ,torque converter,or some other nightmare ,any suggestions appreciated,.........thanks in antisipation
