rwd
Hi everyone
I'v had an issue with my mercedes today. I drove up to a mate's place today and the car drove fine. While waiting for him on a downhill slope, i had the car running with handbrake engaged. However, when i wanted to move, the car only moved forward slightly but then it wouldnt move at all! Revs wont go up if i select reverse or drive, but they do go up if i rev the car in neutral!
Because the car had moved, i was stuck on a junction with half of the car on a busy road and half of it on a side road! I put the car in neutral and managed to push it onto the main road and parked it up sideways while pushing it. I locked the car using the key fob.
On a second thought, i realised that considering that it's a busy single carriage way, and car was parked on a slight bend, it could be a potential hazard if i left the car there.
I decided to push it further forward so I unlocked the car and tried to move it. The car started fine and to my surprise, i was able to drive it as normal. However, after 2 minutes of drive, the revs started being weird again, I had my foot on gas and the engine was producing the usual level of sound/noise but the car wasnt moving as quick as it should. Then a sound started coming from somewhere, which sounded like a drill machine being run (not being drilled).
I managed to get home and parked it up, opened the bonnet to see if i could smell anything but there was nothing. It couldnt have been parked for more than a minute. I started the car again and felt that the power had returned! But the same problem happened again after a bit of drive.
Could an expert please point me towards what the fault could be? Thanks in advance
