W211 Speedo - replacement
grahamwoodward
Midlands
www.gwoodward.co.uk
W211 E320 (petrol) Avantgarde Saloon (2004); CL203 CLC180 Kompressor Sport (2008)
If I replace the speedo binacle in my W211 E-class will I retain the original mileage figure? My E-class has a speedo in km/h and I am thinking of changing it for one showing miles.
star
Reading
Smart + others :)
On a new cluster it can, if second hand no. You could get it virginised and do an initial start up.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
OK guys. Thanks. I'll probably leave it then - at least I'll be several hundred pounds in pocket!
RUBBER_UNDIES
2003 w211 E270 177 BHP
You could buy a can blocker that goes between the clocks and the harness. It's only used when synchronizing the mileage with star. If the clocks are second hand of course.
Alfie
Surrey/Cotswolds
www.comand.co.uk
Just changing the cluster wont alter the display. The car will need proper coding online with Xentry and as already stated, the cluster must be new or at least professionally reset to zero.
www.ckinsurance.co.uk
