W212 HIGH IDLE WHEN HEATER IS ON
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Quaver, Jan 19, 2018.
  1. John Laidlaw
    John Laidlaw Senior Member
    16,585
    3,857
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    Thanks , I shall take that ‘under advisement ‘ as they say
    Paul Goff likes this.
  2. Botus
    Botus Senior Member
    2,423
    324
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    put in the 50ml take the lids off an tip it upside down NOTHING will come out
    your method will use up more of the worlds resources unnecessarily
  3. John Laidlaw
    16,585
    3,857
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Think we may be on that way already with 5.5 litre engines;)
    Paul Goff and Frosty149 like this.
  4. Frosty149
    Frosty149 Senior Member
    2,188
    570
    Jan 9, 2017
    Garden of England
    Your Mercedes:
    W207 '63 E350 coupe amg sport
    Plant a tree?
  5. John Laidlaw
    16,585
    3,857
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Did that in ‘73..
    “Plant a tree in ‘73” - we don’t have initiatives like wot we used to anymore!:shock:
  6. OP
    Quaver
    Quaver Senior Member
    8
    Sep 11, 2017
    Your Mercedes:
    W212 E350 2010
    So just a update, I changed the battery but the EML still appears. I was thinking that the high idle is probably due to the cold weather and it has been like this for a while without the EML but is still weird that it returns to normal after the heater is turned off. I also noticed that the heater doesn't blow full power on max like it used to so I changed the heater blower but still no change. So maybe there is another fault with the heater or seperate fault??
    I did another diagnostic and the following have appeared pictured below but bearing in mind that the following have come up for last year without EML. Also like to add that the fault about low power supply is not showing anymore so maybe just a glitch as this happens with numerous faults before but that particular fault has appeared more than once. Please advise thanks
  7. OP
    Quaver
    8
    Sep 11, 2017
    Your Mercedes:
    W212 E350 2010
    So these are the only 3 faults showing on my Carly. I don't think Carly does show every single fault like STAR so might be missing something. To be honest I don't think these faults are what's causing the EML could be wrong but the DPF sensor has been rewired and the left signal is working fine.
  8. John Laidlaw
    16,585
    3,857
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Disappointing!
    Not used Carly, I think it needs a Star diagnostic to figure this out I’m afraid or even the icarsoft might help. Where you based?
  9. Mr Filipov
    Mr Filipov Senior Member
    655
    107
    Dec 31, 2015
    Huntingdon
    Your Mercedes:
    2014 BMW 530d Gran Turismo
    The high idle has nothing to do with the battery. The car is getting the car and cabin up to temp faster. Mine does exactly that as well.
    And not to mention that you are running ac, music, lights etc. All that is putting a drain on the battery.
  10. OP
    Quaver
    8
    Sep 11, 2017
    Your Mercedes:
    W212 E350 2010
    Looks like I might have to get it hooked up to another diagnostic and see what comes up. I'm in Wembley
  11. OP
    Quaver
    8
    Sep 11, 2017
    Your Mercedes:
    W212 E350 2010
    That's what I thought aswell. Does yours drop back to normal idle once warmed up coz mine don't and it's weird that it stays normal if I leave the heater off
  12. John Laidlaw
    16,585
    3,857
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Wayne Gates in Harrow will do you nicely
    Quaver likes this.
  13. Mr Filipov
    655
    107
    Dec 31, 2015
    Huntingdon
    Your Mercedes:
    Generally drops the idle when the car gets to 60 deg coolant temp. During the summer months don’t even get high idle.
  14. OP
    Quaver
    8
    Sep 11, 2017
    Your Mercedes:
    W212 E350 2010
    Is that a Mercedes specialist?
  15. mikestrivens
    mikestrivens Senior Member
    2,715
    145
    Nov 21, 2008
    Stockport
    Your Mercedes:
  16. John Laidlaw
    16,585
    3,857
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Quaver likes this.
  17. Botus
    Botus Senior Member
    2,423
    324
    Jul 29, 2014
    Your Mercedes:
    S500/2010/500
    it most certainly isn't (its really your worse enemy... but it is pretty good at searching stuff.... while selling your soul to the devil)
  18. mikestrivens
    2,715
    145
    Nov 21, 2008
    Stockport
    Your Mercedes:
  19. mikestrivens
    2,715
    145
    Nov 21, 2008
    Stockport
    Your Mercedes:
    You must be analog man!!
  20. OP
    Quaver
    8
    Sep 11, 2017
    Your Mercedes:
    W212 E350 2010
    so i took it to wayne gates and they said that the whole idling thing with the heater is normal o_O But still couldnt get a definitive answer regarding the EML as they suspect its something to do with the dpf removal process and remap but i didnt get a remap and the car has been running fine for the last 2 months until i started experiencing these issue. i still think theres a issue somewhere around the heater. something that has come up on my own diagnostic is temperature sensor left footwell vent. would this cause the EML to come on? also since i took it to wayne gates the EML doesnt go away after i clear the codes, coincidence or what?
    there are a few codes that has no explanation on my Carly adapter so if anyone knows what these codes are please let me know, i have attached a picture showing the 4 faults. thanks
Share This Page
