W212 panoramic roof help!
NinjaZ
London
2009 w212 E350
Hi guys need a bit of help regarding a piece of trim from the panoramic sunroof.
The trim that holds the wind deflector in place at the very front has come off and although I have tried all sorts of angles and positions to slot it back in it doesn't fit and just pops off again when I let go. I bought the car like this so I don't really know how it happened. Has anyone had this issue before or know how it should be assembled?
Thanks in advance!
This is far too complicated to write out, pop up you Email address and I will send it
N
NinjaZ
London
2009 w212 E350
Thanks Malcolm, I have sent you a private message
I have sent it :D:D
N
NinjaZ
London
2009 w212 E350
Received buddy, thanks again
N
NinjaZ
London
2009 w212 E350
Just took the whole wind deflector off and it looks like I would have to remove the front glass portion of the pana roof to refit the bit that came off which looks a pain in the backside!
I may just do without the wind deflector as that's it's only purposes think, it doesn't look like it acts as a seal or anything....
I can print off the info for doing this for you.
N
NinjaZ
London
2009 w212 E350
If it's not too much trouble that would be good Malcolm. I may try and fix it if it isn't too big a job, if not I'll just leave the deflector off. I actually emailed you regarding where you got the instructions from as they seem really useful!
Yes I have the Email, I will deal with it and you can see whats involved '
N
NinjaZ
London
2009 w212 E350
Cheers mate, no rush. Thanks!
mueed
Lahore, Pakistan
2010 Mercedes e250
Exact same problem
Hi I have the exact some problem could someone guide me how to fix this? and is it easy to fix at home?
mueed
Lahore, Pakistan
2010 Mercedes e250
Hey I have the exact same problem with my car could you guide me too? and is it easily fixable at home?
N
NinjaZ
London
2009 w212 E350
Hi Mueed, I never got around to fixing it as it looked a pain fix so I just took the deflector off in the end. I don't use the sunroof that often so I'm not too bothered...
Ricky
TK1851
W212 E350
I have the same fault, wouldn’t you believe it when it’s sunny! Can you help me ?? I’m an engineer so able to follow instructions. Thanks!!
TK1851
W212 E350
Hi, I have the same fault with my sunroof wind deflector. You mentioned you have instructions how to correct it, could I possibly get a copy. I’m an engineer so I have star keys and tools to get into most things. Much appreciated
John Laidlaw
Wirral
Land Rover Discovery 4
Sadly Television (Malcolm) passed away last year- Lost Kiwi on here has a lot of his old files though I’m sure he’ll see this at some point
TK1851
W212 E350
Oh god, I’m sorry. Really awful, I’ll sort it but my condolences and best wishes
Steve66
Registered
W212 E350 AMG
Hi, I have exactly the same fault on my E350, did you manage to get a resolution / fix on this problem any assistance would be most welcome, I am also an engineer so tooling is not an issue. Many thanks in anticipation
Mangahuisman
s212 2009 e200cdi
Can anybody please help me or post the instructions? i have the same problem?
Any help?
  • 212 wind deflector.pdf
