I doubt it, MB keep the same design concepts over decades..!Thanks C, later models are 501 W5W...I wonder if the bulb holder operates in a different way.
Found the answer.
For W5W in the W215...the holder pulls out (not easily).
Both hands are in pain...bulb still not out. Will use bent long nose pliers.Did that cause you a gashed wrist?
I'm trying to replace the off side one (MOT next week).
1. Remove pump for headlamp washers.
2. Remove H7 main beam lamp.
3. Struggle to find a way of gripping lamp holder.
I think the nearside is impossible without removing the bumper and lamp assembly.
I saw that David and realised mine was the same. Can't make the tool though until I get one out.Sounds exactly like the W169 side lights - W5W, and impossible to grip with your fingers.
I made this, admittedly not pretty, contraption - works perfectly well though:
Despite the rough look, it's actually polished to smoothest possible finish and locks on a bulb holder almost by itself - it's a second prototype - the first one (plastic) required a bit of twisting of the holder to align, this one is self-locating ... sort of
It was either the crossmember or some of the ABC kit, I can't remember what was in the way.I thought about the cross member...but not at home so, few tools.
You can get a pair of W5W sockets from Amazon, with next day delivery for a couple of quid, then you'll have a test one to work with?I saw that David and realised mine was the same. Can't make the tool though until I get one out.
I was considering a spark plug remover - like the pliers, but with what looks like a much more suitable grip.I'll try bent long nose pliers later.
